Building a café racer called „Uschi“
joecoolsuncle
Re: Building a café racer called „Uschi“
#301
Post by joecoolsuncle »
i bow! but you missed my house....................................
LastMohawk
#302
Post by LastMohawk »
Hello everyone,
It continues on the bike, what did I do today?
First, I have rebuilt the pillion footrests. The beautiful ones with the Honda writing. They probably come from the Anglican area and had an inch fine thread with about 10mm width. I had then converted the whole thing to M10x1.0 and screwed. Now it looks more coherent. dancr
The footrests are indeed protruding, but the motorbike is also no lightweight.
Then I had to rebuild the side stand so that it retracts by itself. I did not want an electrical solution with any contacts . The side stand does have a rubber tongue that is supposed to push it back up when it touches the ground while riding, but that is no longer appreciated.
The GL1100 already had a spring mechanism that pulls the stand up when unloaded. So without further ado bought such a stand together with the spring mechanism and tested it. But I did not like him as well as the old. So from the 1100er stand the spring mechanism adapted to the 1000er stand. And what can I say, works. action1
And then again sample sat. Is already a nice feeling to have so much motorcycle between the legs. :crosso
Then noticed that the right rear Koni shock absorber bleeds and it smells strongly of damper oil ... so without further ado ordered two YSS shocks. I want the bike to drive decently.
Meanwhile my two Beemer had to wait in the rain until the garage is free again. I found out that the Hawker battery of the Caferacer has given up and I ordered a new battery. It will be again ne 14Ah gel battery, because it must be under the transmission.
I wish everyone a happy Easter
Harald
"Sometimes it takes more than luck to keep the wheels spinning just right."
77 GL1000 "Uschi"
#303
Thanks for the update. Bikes still look great action1 action1
#304
Keep up the amazing craftmanship. Nice work
LastMohawk
#305
Hello,
the rebuilding of Uschi continues slowly but surely.
What have I done this week?
I finally mounted the upper triple clamp, which was relieved by the handlebar brackets, and moved the ignition lock so that it no longer protrudes above the triple clamp.
The tachometer is intentionally a little off-center, I like it better that way.
Then I replaced the right dash, because by some mishap the parking light cable got crushed and when I turned on the ignition the cable and switch went up in smoke.
Here is a look at the triple clamp.
and with the mirrors
from the front it looks like this:
Then I continued to work on the wiring, but is still a bit to do.... on the picture above you can see my wiring harness drawings. I expand them after each activity on the harness, otherwise I don't remember what I wired and how. I cut out the whole wiring harness and redo it completely.
Then the Brembos P4 got new steel flex lines. The steel flexes for the Honda two piston calipers no longer fit. As a scuff guard, I found some nice aluminum hose holders on the net and they migrated to the front fender today.
The Brembos are currently still sitting on holders made of wood. I finally found a suitable and willing cutter to mill out the adapters for the calipers.
Here's a picture of the Brembos in the front wheel ...
I think they look delicious and together with the radial brake pump they really pack a punch. Bleeding the new steel flex lines is really easy with the Stahlbus valves.
And finally, a look at the Wing from behind. I think you can speak of a wasp waist even on such an iron pig, right?
I wanted to be much further along, but unfortunately something always gets in the way. The other day I was on the road with my old Beemer (the silver one) in the Black Forest and on the way back the rear gear oiled directly into the brake. Stupid only that this then no longer squeaks, but also otherwise stopped its service.
The cardan was knocked out and so I had to push this between. The rear gearbox unceremoniously replaced by another from a replacement motorcycle and disassembled the cardan and replaced the shock absorber. Now it runs like a young calf again. And that after 200,000 km.
But my other Beemer (the blue one) wants a new set of cylinders and pistons this winter. It smokes blue like an old 2 stroke motorcycle.
Work enough hehe...
But I haven't given up hope yet to get the Uschi on the road next year.
Greetings
Harald
77 GL1000 "Uschi"
#306
looks like good progress.
#307
Nice progress and documentation. Loving the progress. Chip, Chip, Chip...
LastMohawk
#308
Hello everyone,
I haven't done anything to the Uschi for a long time, well, other projects and my accident in September kept me away from it a bit, but today I finally made the breakthrough, the Brembo P4s now fit cleanly on the fork and have enough clearance to the spokes. The fork is not braced and springs cleanly and the wheel turns cleanly in the calipers.
Now I can have the brackets milled from the appropriate aluminum. That was my biggest problem for a long time, getting everything to fit together. Well, sometimes you just have to let time pass and then you find a solution.
Here is the bike without the fender
Brembo Ohne Fender.jpg (85.61 KiB) Viewed 884 times
And I still have enough clearance between spoke and caliper. Here is the left side
Speichenfreiheit links.jpg (58.56 KiB) Viewed 884 times
The disk also runs in the middle of the caliper
Schibenlauf links.jpg (72.29 KiB) Viewed 884 times
And this is how it looks with the fender. I think it looks delicious.
Brembo mit Fender.jpg (90.47 KiB) Viewed 884 times
The sensor for the speedometer still needs a proper mount so that it doesn't tear off and doesn't hit the disk.
Slowly but surely things are moving forward with the old girl.
Greetings
Harald
77 GL1000 "Uschi"
wingrider
#309
Post by wingrider »
Very nice! Good to see you working on it!
#310
Looking quite delicious for sure, nice update.
#311
Beautiful … now take us on one of your great rides
Gord anim-cheers1
LastMohawk
#312
Hi there,
I had some time yesterday to continue working on Uschi, as I'm still waiting for two or three parts for the fork conversion of the Beemer.
I finally got hold of a shorter chrome fender. The one from a CX500C. I just had to bend the brackets a centimeter or two further apart and then it fitted the GL fork like a glove. Of course, the fender light must not be missing
But take a look for yourself.
Here is the original front fender
alter Fender.jpg (91.45 KiB) Viewed 756 times
and the new mudguard from the CX500C.
neuer Fender.jpg (81.36 KiB) Viewed 756 times
makes for a slimmer foot. As you can see, the girl is making progress.
Greetings Harald
77 GL1000 "Uschi"
Dirt Road Cowboy
#313
Post by Dirt Road Cowboy »
Very nice! Glad to see that you're still making progress.
78 GL1000
DirtRoadCowboy.com
wingrider
#314
Post by wingrider »
Very nice! I cut one down a couple years back to just about match what that CX one did for Uschi!
