Page 1 of 1
First Goldwing, first cafe build
Posted: Wed Mar 11, 2015 4:56 pm
by redimension
Hey guys, picked up my first goldwing last night. '77 gl1000. Ive had plenty of other hondas, all newer. This will be my first older build.
Supposedly, the timing belt(s) snapped on it. I pulled the plugs before buying and didnt see anything catastrophic but there was quite a bit of carbon build up. Bike is fairly clean overall and the PO had done a decent amount of work already towards making it cafe. RF caliper is leaky and battery needs to be recharged at the least.
I borrowed the nice snap-on camera tool from my shop today to have a better look inside. I noticed what looked like may be a nick on the right side forward piston. So, I'll retime it this weekend and try to fire it up and see what happens.
Probably wont do too much to the bike, finish the small things. I plan on getting a new seat. I'll do a new cluster setup as well, probably two mini gauges for mph and rpm. Repaint the tank and side covers, polish the wheels and make an exhaust.
Anyways, here it is. Ill post a better picture tonight.
Re: First Goldwing, first cafe build
Posted: Wed Mar 11, 2015 5:09 pm
by Earl43P
Welcome, you'll like it here.
Heads are available if you end up needing one. Use OEM head gaskets. Might as well lap the valves, etc.
Get your 5 posts, quick and read Shoptalk.
Posted: Wed Mar 11, 2015 5:14 pm
by Kriss
:2thumbs Welcome to the hub, right side front is No 1 cylinder you may have bent a valve.
Posted: Wed Mar 11, 2015 5:23 pm
by redimension
Thanks for the warm welcome. Ya, I've already shopped out heads, they are cheap. My good friend runs a Head shop, so that will also be cheap, if needed. I've also read a few places that OEM head gaskets are the ONLY way to go on these. So I wont be taking a shortcut there.
Posted: Wed Mar 11, 2015 5:54 pm
by chewy999
Welcome from the UK. Hope there wasn't to much damage if the belts did snap. New members are always being told to change the belts before anything else. Be interesting to see what happened if they did, you may be lucky but if not, this is the place to get help.
anim-cheers1 anim-cheers1
Posted: Wed Mar 11, 2015 9:11 pm
by sunnbobb
Good luck and welcome on board!
Posted: Wed Mar 11, 2015 10:09 pm
by redimension
Alright, so I pulled the timing cover tonight. Guess what! No broken belts. So thats a good thing. Motor turns over. Here is a picture, Im going to go start a tech thread now. Thanks everyone!
Posted: Thu Mar 12, 2015 5:05 am
by chewy999
redimension wrote:Alright, so I pulled the timing cover tonight. Guess what! No broken belts.
That's good news, but change them anyway!
anim-cheers1
Posted: Thu Mar 12, 2015 5:30 am
by TNTbefree
That is some good news. She is a looker. It is none of my business, but if you picked her up under the assumption that the timing belts had snapped, I hope you got her for a song.
Posted: Thu Mar 12, 2015 3:31 pm
by Rat
Welcome to the 'Wingdom.
Great start ......
Posted: Fri Mar 27, 2015 11:06 am
by sj2000
May I know how much did you pay for the bike? thanks.
Posted: Fri Mar 27, 2015 11:15 am
by Gowing
Back in the early 90's I stopped roadside to look at a clean little 81 honda accord four door
Automatic with air with 75000 miles. $400 dollars. I called the number and they lived a block away. An 18 year old came over. The car beLonged to his grandparents. I bought it. It was running very ruff. Got it for $250 with the snow tires at home in garage.
When I got it home I found an unhooked spark plug wire. That kind of deal has not come up since. I keep looking.
Posted: Tue Mar 31, 2015 10:59 am
by rcmatt007
welcome to ngw.... the right price is always the one that leaves buyer and seller happy!
