Page 1 of 3
How To Use The Kick Starter
Posted: Thu Apr 12, 2007 7:23 pm
by RebelRouser
The Kick Starter Tool Is Stored In The Right Side Of The Pod/Faux Tank Behind The Side Cover Next To The Overflow Bottle
Looks Like So....
On The Rear Left Side Of The Motor Behind The Stator/Altenator Is The Kick Starter It's Self....
Remove The Rubber Dust Cover
Tool Goes In Here
Has A Flat Spot So It Won't Roll Left To Right...
Just Step Down
Posted: Fri Apr 13, 2007 6:47 am
by the555
Thanks RR, I was wondering how to use that lever. It seemed to be turned the wrong way when I looked at it. Tim
Posted: Wed Apr 25, 2007 4:46 pm
by ProbeDaddy
I've never tried using mine. Any danger of kick-back?
Posted: Sat May 05, 2007 12:15 am
by Dave of Hutto
I would have to take a brass wheel to that and maybe a little naval jelly.
Posted: Thu May 24, 2007 9:04 pm
by ProbeDaddy
Cool. Took mine out and gave it a try. Cranked with no problem!
Posted: Thu May 24, 2007 9:45 pm
by LesTension
Weahhh... I don't have one. any ideas?
Les
Posted: Thu May 24, 2007 9:48 pm
by ProbeDaddy
What year you got, Les? I believe it was only the '75 that had the kick starter.
Posted: Thu May 24, 2007 9:58 pm
by LesTension
Nope. My '76 is s'possed to have one. At least it's got the rubber covered port by the generator anyway.
Les
Posted: Fri May 25, 2007 2:41 am
by octane
75, 76 and 77 had them.
Posted: Fri May 25, 2007 3:57 am
by RebelRouser
Les Get Ahold Of Frenchy, Sure He Has One Or Two Lying Around
http://www.crescentmoonunlimited.com/ht ... parts.html
Posted: Fri May 25, 2007 9:30 am
by Frenchy
LesTension wrote:Weahhh... I don't have one. any ideas?
Les
What year is your bike? Mother Honda felt that there was no real need for the auxilary kick start, & dropped it with the 78 model..
Posted: Fri Jun 08, 2007 4:50 am
by ffwd
is the kickstarter working? I was thinking of keeping it as a permanent starter(since I like kick starters soooo very much),and drop the electric starter.
Posted: Fri Jun 08, 2007 9:31 am
by RebelRouser
It All Depends On The Running Condition Of Your Bike... I've Seen Some That It Never Wored On At All, Like My 75, Low Compression, And Some That It Works Every Time, Like My 76....
Posted: Thu Aug 02, 2007 5:22 pm
by doncoyote11
Is the lever supposed to spring back up? Mine is quite difficult to depress then I have to pull it back up. It starts, but groans as I lift the lever back up.
Posted: Fri Aug 03, 2007 2:12 am
by RebelRouser
No Spring, Or Kick Back, You Should Have To Lift It Back Up, Thats Normal, A Well Graesed Bike Will Return To The Top, But Not With Any Presure
