GL1100 drive shaft lengths
Moderators: robin1731, CYBORG, Oldewing, Forum Moderators
Old Fogey
Post by Old Fogey »
I know that the early and late 1100s had different drive shaft lengths, the later most likely the longer.
I have a real good 1100 shaft here, but as I don't know what length either of them are, I don't know which shaft I've got! :oops:
Could some kind soul help me out? I need one measurement from a known year shaft, say from top to bottom.
wog
Re: GL1100 drive shaft lengths
Post by wog »
Don't have one totally out, but an '83 measures appox 16.5" (41.9 cm) from the front of the shaft to the end of the rear splined joint. Didn't have snap ring pliers handy to remove the rear C-clip.
Have a '80, but it's still in the bike.
Seems like everything on the outside measures the same.
But, different part #'s on the shaft and splined jount.
wog
Post by wog »
Did notice one difference on the swingarm.
The early one was sleeved and plug welded at the rear, '83 is not (held in the foreground in the pic).
Old Fogey
Post by Old Fogey »
Thanks for looking. I knew that the two different combinations were approximately the same length, but that still leaves the question of the shaft lengths, unless you could measure up the attached coupler to the end of the shaft and subtract that from the total length for me?
wog
Post by wog »
It will be tomorrow, but sure.
wog
Post by wog »
'83 little over 14"
Also, if this helps, the '83 has the number 5 cast into the front end where the '80 has what looks like a 2.
Old Fogey
Post by Old Fogey »
Fantastic! Thank you so much for your trouble..
Sandy
Post by Sandy »
Old Fogey wrote:I know that the early and late 1100s had different drive shaft lengths, the later most likely the longer.
1976 is the short one, 1980 or 81 is the longer unit.
76 81 drive shafts.jpg (56.25 KiB) Viewed 345 times
Sandy
1971 Honda CB350
1974 Honda XL350
1975 Red GL1000 (gone from stable but still in the family)
1976 (original owner in 76) Sulpher Yellow GL1000
1977 Restored then Triked Sulpher Yellow GL1000
1976 (garage find completed 2015) Sulpher Yellow GL1000
1978 Watsonian Monaco
1960 IH B414
http://www.flickr.com/photos/76_gl1000_project
Captain Midnight
Post by Captain Midnight »
Sandy wrote:1976 is the short one, 1980 or 81 is the longer unit. longer.
[/quote]
...isn't he asking just of the two available 1100 length differences; long and short?
...isn't he asking just of the two available 1100 length differences; long and short?[/quote]
Thats what I thought he was asking
On to what we really want to know. Is this an attempt to get a replacement shaft going? (Ujoint)
Old Fogey
Post by Old Fogey »
Yes, he is!
ericheath wrote:On to what we really want to know. Is this an attempt to get a replacement shaft going? (Ujoint)
No, he's not!
That is a project that has stalled through lack of focus. One day.............
It's just that I have got in a very good 1100 shaft which I needed to know about so that I could sell it.
Anyone need this shaft for their late 1100? Make me a reasonable offer. Perfect U/J, excellent splines at both ends.
