1978 GL 1000 JUNK YARD DOG PROJECT
gdonlo04
Re: 1978 GL 1000 JUNK YARD DOG PROJECT
#31
Post by gdonlo04 »
. finished the paint on the controls. This craft pin applicator did great not to mention the magnification glasses too.
#32
Wow! Turned out great! action1 action1 action1
gdonlo04
#33
Post by gdonlo04 »
THANKS. i just realized i forgot to paint the bottom TURN L R . Back to the paint shop.
gdonlo04
#34
Post by gdonlo04 »
Trying to get a beautiful polished look. Having issue with reaching that goal. cant quit get the final look right. too many swirl marks. any suggestions?
#35
in polishing you need to go with finer and finer polish media. If you are using the same bonnet there still will be coarse materiel. Also, how mush pressure you apply makes a difference
gdonlo04
#36
Post by gdonlo04 »
my sanding wheels only goes to 320. The only 1200 paper i can find is wet/dry paper. looking for 2000 or 2000 paper too. Making sanding a painful process. i have a buffing wheel from Eastwood but cant get the rim on that. looking for other drill attachments for polishing. cant grasp the correct wheel and polish stick. i will reread the section on polishing. big diff between ready about a doing. thanks
Sagebrush
#37
Post by Sagebrush »
Take it in stages down to 1000 wet and when you get it even at that point go get a Mothers cone shaped power ball available at Walmart. Use a good grade of liquid polishing compound (very fine) on the cone and begin to work it around all your corners and crevices with the drill mounted cone. Wipe clean and you will have a mirror like finish depending on how well you did with the sandpaper.
#38
ditto.... 320 is removing not polishing.... there is even 2000 wet/dry
pidjones
#39
Post by pidjones »
2000 at most auto parts stores and Walmart. Up to 7000 grit on Amazon. Soak the paper overnight before using and keep it wet with water and a drop of dish washing liquid. Use a block on flat areas.
Jonesz
#40
Post by Jonesz »
GR8 info on doing comstars, going to need this info in the long run. Would love polished aluminum wheels to match polished timing belt covers, valve covers and carb tops. Thanx
Jonesz
1979 Suzuki GS850. Sold
OCR
#41
Post by OCR »
Toothpaste also makes a good substitute for polishing compound.
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
#42
lololo it is polishing compound
CrazyJerry
#43
Post by CrazyJerry »
OCR wrote:Toothpaste also makes a good substitute for polishing compound.
What OCR said . action1
~CrazyJerry~
5speed
#44
Post by 5speed »
pidjones wrote:2000 at most auto parts stores and Walmart. Up to 7000 grit on Amazon. Soak the paper overnight before using and keep it wet with water and a drop of dish washing liquid. Use a block on flat areas.
curious. why should the paper be soaked over night?
pidjones
#45
Post by pidjones »
Makes is flexible so it will conform to curves. Keep it wet to keep the paper cutting by keeping the grit matrix open.
