GL1000 build - soon to be Fuel Injected
Re: GL1000 build - soon to be Fuel Injected
Post #31 by ericheath » Thu Feb 07, 2019 10:20 pm
Recent posts here give options. See Sidecarbobs post. viewtopic.php?f=1&t=66698&start=15
GT-Ron
Zinc Member
Zinc Member
Post #32 by GT-Ron » Sun Feb 10, 2019 12:02 pm
low-side wrote:I'd carve most of the rubber off of those intake runners with a knife and remove the rest with the brass brush on my bench grinder myself.
Low side the wire wheel on the bench grinder worked a treat. Thank you.
While i was there i gave the runner a quick brush and light polish. I think i may do this to the runners instead of vapour blasting them.
Ps: what is everyone using for polishing? I would like a finish thats not too shiny.
I also stripped down the spoke wheels a few days ago. The spokes were pretty rusty. If you zoom into the pics you can see.
Needed some heat to break loose a few of the nipples. Then i threw the spokes in a container of evaporust. The evaporust did its job of removing the rust. But the spokes looked blackish and dull afterwards. You can also see the layer of rusty scum that drifted on top of the evaporust left behind on the spokes.
Decided to experiment with the wire wheel, and sure enough, it worked very well. Even on the threads and the nipples. Couple of hours later my spokes look like almost new.
Lastly i got all the parts sent off to the vapour blaster.
'75 GL1000 project, '82 Kawasaki GT750 turbo project.
ex: K6 GSXR1000, '07 Hyabusa
pidjones
Post #33 by pidjones » Sun Feb 10, 2019 9:18 pm
>Ps: what is everyone using for polishing? I would like a finish thats not too shiny.<
I use sequential grades of silicon carbide paper under a lightly running water tap. And lots of elbow grease. For more polish, rouge and the buffing wheel in my drill press. Hope the spokes have not thinned too much. It is a heavy bike.
2006 GL1800 - the Black Pearl
1979 GL1000 project - to be restored
Ex '79 CB750F rat bike - the Rocket - SOLD!
Ex '75 RD400
Easter
Post #34 by Easter » Sun Feb 10, 2019 9:36 pm
Interesting project. I am along for the ride.
80 GL1100 Interstate: Now a Cafe Racer called DRAGON WING.
81 GL1100 collecting dust with about 300,000 miles, known as BLACK BEAUTY
2008 (I think) GL1800 Nice bike but as exciting as the family sedan!
76 GL1100 yes, 1100 with 1000 heads and cams, being customized
A fleet of parts bikes awaiting resuscitation or customization or abandonment :IDTS:
GT-Ron
Zinc Member
Zinc Member
Post #35 by GT-Ron » Mon Feb 11, 2019 2:15 am
pidjones wrote:>Ps: what is everyone using for polishing? I would like a finish thats not too shiny.<
Thanks will try some out and see.
Ps: i dont think any metal was removed from the spokes. The brush was gentle enough to even clean the threads and the nipples still screw on fine.
Dont have a digital vernier but the regular one says the spoke diameters measure 4mm and 3mm after the step.
OCR
Post #36 by OCR » Mon Feb 11, 2019 11:49 am
I find that a wire wheel will leave a "brushed" look without being too glossy.
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
GT-Ron
Zinc Member
Zinc Member
Post #37 by GT-Ron » Mon Feb 11, 2019 12:31 pm
I have nothing to compare them to but they look perfect to me for what I’m doing with the bike. There is minor pitting on the spokes from the rust it had before, but nothing you’re gonna see from 2ft+ away.
I could go after it with some autosol metal polish for a high shine but probably wont. The way i look at it i saves about $150+ towards other electronics needsd for the efi.
GT-Ron
Zinc Member
Zinc Member
Post #38 by GT-Ron » Mon Feb 11, 2019 4:45 pm
Back to the waterpump saga. It just seems like the pump is still too good to throw away right now. So i picked up a “cheap” bearing at the local bearing shop, and donated its dust seal to the ntn bearing in the water pump. I added a small amount of grease. The seal went in easily and the pump spins firmly but with no sideways play. So going to give it a go.
Also spent some more time behind the bench grinder and wire wheel. These intake tubes have close to a stainless finish so far. I like it!
Next up, getting the frame and other bits to the powdercoaters. Need to go purchase some needle nose pliers to get the driveshaft removed from the swingarm...
pidjones
Post #39 by pidjones » Mon Feb 11, 2019 5:17 pm
Needle nose for the driveshaft? You need straight external circlip pliers to remove the circlip from the slip joint end. Then it should slide right out. There is a grease seal in the end surrounding the slip joint. Use care with it as they are unobtainium.
Ex '75 RD400
GT-Ron
Zinc Member
Zinc Member
Post #40 by GT-Ron » Mon Feb 11, 2019 5:56 pm
Almost forgot. My one assistant testing out the kawasaki er6-n seat I thought i may make work on the goldwing...
GT-Ron
Zinc Member
Zinc Member
Post #41 by GT-Ron » Mon Feb 11, 2019 5:58 pm
pidjones wrote:Needle nose for the driveshaft? You need straight external circlip pliers to remove the circlip from the slip joint end. Then it should slide right out. There is a grease seal in the end surrounding the slip joint. Use care with it as they are unobtainium.
Thanks yes i meant circlip not needle nose. Its kinda late here ;)
GT-Ron
Zinc Member
Zinc Member
Post #42 by GT-Ron » Tue Feb 12, 2019 3:46 pm
pidjones wrote: There is a grease seal in the end surrounding the slip joint. Use care with it as they are unobtainium.
Pidjones do you mean no 15 in this schematic?
Mine was missing when i got in there....
Just copious amounts of grease everywhere.
GT-Ron
Zinc Member
Zinc Member
Post #43 by GT-Ron » Tue Feb 12, 2019 3:48 pm
On a related note:
How can i protect the swingarm bearings while it goes in for sandblasting and powdercoating?
Or should i just leave the old ones in to take the beating (while protecting swingarm) and replace them anyways?
Post #44 by ericheath » Tue Feb 12, 2019 4:28 pm
I think most 75’s didn’t get the grease seal.
GT-Ron
Zinc Member
Zinc Member
Post #45 by GT-Ron » Tue Feb 12, 2019 5:57 pm
Good to know thanks eric
Who is online
