2023 Bike Of The Year voting in the Clubhouse
https://ngwclub.com/forum/viewtopic.php?t=78498#p821785
Phat GL: Formerly known as the 82 Bagger
Re: Phat GL: Formerly known as the 82 Bagger
Wow! Tuned in with great interest!
Nice progress!
The part in question is for the self cancelling directionals, IIRC...
On a long and lonesome highway, East of Omaha, You can listen to the engine, Moanin' out his one note song,
You can think about the woman,Or the girl you knew the night before Phat GL you left at home the night before...
But your thoughts will soon be wandering, The way they always do,When you're ridin' sixteen hours,And there's nothin' much to do, And you don't feel much like ridin', You just wish the trip was through You'd rather be home wrenching cause there so much left to do...
Thoughts on gauges?
This is ugly and blocks my windshield:
So what if I move the auxiliary gauges down onto the shelter lid, like on a 78? Although I might just flush mount them in the tin and not build a housing.
Fuse block and radiator bottle will need to move:
Not an issue for the fuses, they are all getting replaced with blade fuses once the bike is running. They can move elsewhere under the shelter pretty easily. The coolant overflow tank could move also, but what about...
using one from a 70's GL1000 instead?
I could probably make that work.
These gauges (or very similar) would fit with the retro theme OK and still be modern electronics.
And they're small. And cheap - ish.
I'll need to make a bracket/housing for the speedo,tach, high beam, neutral and turn signal lights up above the bars but that's no big deal. I'll likely use the existing stock bracket with some modification. And get my GPS speedo I wanted.
What is required on the sender end to convert the oil dummy light and add the voltmeter?
We have a plan...
On the other end, with the Sturgis bike week rally going on this week, there was an opportunity to see lots of mechanical eye candy, which gave me some good ideas for the back end of the bike.
Once the bags are done, I'll have to build some sort of filler between the bags and the fender. And the exhaust has to poke out too.
These gave me a few ideas:
I think I can run the exhaust between the lower part of the bags and fender, with the ends poking out a few inches past the bags and fender to expose the fishtails. I'll glass in the gap between the fender and bags above the pipes, probably mount led brake lights in there too.
Thoughts on gauges?
We have a plan...
A few of my favorite things...
82 GL1100 Interstate - The PhatGL - Current Project
77 GL1000 - Next on deck - will be converted to a dual sport
99 Vakyrie Interstate - Daily (when the weather is nice) Driver
78 GL1000 Vetter - Restored to original - Sold
79 GL1000 Vetter - Refurbished as a Driver - Sold
78 GL1000 Naked - Project I never got around to - Sold
78 GL1000 "Old Gold" - The one that started me on this crazy path- Sold
95 20th Anniversary 1500 Wing - Sold
99 Kawi Drifter "Faux Indian" - Sold
03 100th Anniversary Harley Heritage Springer Softail - Sold
She Lives!!
Got it cranked and running in the shop today. First time she's ran in over a decade, maybe first time this century. She was a barn find that had been sitting for at least 10 years according to PO. Still working through the boring stuff on the punch list, but now there's light.
New goal: Make her go down the road and back before the snow flies.
Brakes, engine stuff and carbs are done, rear lights are wired. Front driving lights and signals need wiring and assembly. Seat is still at upholsterer and there's no exhaust yet.
But close. Soooo close now...
- dontwantapickle
what carbs did you put on it?
you were talking about dual Webers at one point.
Original deck. I'll do the webers later once I get it running well.
dontwantapickle wrote: ↑Wed Sep 02, 2020 5:10 pm what carbs did you put on it?
Electric is done, other than swapping out the ugly gauges.
Looks like a motorcycle.
Those are taillight wires hanging, they aren't connected since I'm pulling the tins off soon.
Squatting. The exhaust won't be that low when its done, I'll put a small S bend pipe in to pull it up closer to the frame.
It runs and drives, electric is done. Paint at some point. Bags are still a project waiting to happen. And those ugly gauges...
I like how the curves of the fishtails accent the lines on the fender and skirts.
Were you able to find the time to finish your bike? Thanks.
Actually someone offered me cash for it not too long after my last post. I've since moved on to musclecars. Currently building a squarebody chevy truck.
What year squarebody Chevy. I love the early 60's with my fav 1962. Time to update your signature perhaps.
