Help with keys
77Gowing
Help with keys
Post by 77Gowing »
Went to pull my keys out of the ignition.
But old shakey butter fingers dropped them down in the gap between the triple tree and the shelter front. Looked and looked w flash light no joy.
The Mrs said flip the bike over.
Problem: shelter key and ignition key is on the same ring.
The frame and ignition and shelter is original.
So if I have a valid vin is this doable?
Last .resort...lock smith?
I'm such a foolish dude! lolol lolol lolol lolol :guitar :guitar crying1
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue."
2014 Yamaha 950 V Star (sold)
2017 Indian Scout Std w/ABS
2009 Honda VTX1300R "Me Brudder's"
1984 Honda Interstate "84' 2outa4."
1982 Honda GL1100 "After thought."
flyin900
Re: Help with keys
Post by flyin900 »
Remove the seat and the rear shelter small back cover ( 2 screws) and use a screwdriver to pop the shelter latch. Not having a spare set of keys is a bad situation to put yourself in, so maybe get one cut once you retrieve them.
Current Bikes:
1967 CL175 Low production number with #802 as engine serial- winter 2019/2020 project.
1978 CB550K Very original bike with only 7499 klms from new- light cleanup and refresh pending.
1981 GL1100 Standard model - Sept 2018 start of cosmetic refresh, nice original condition.
1983 CB1000 Custom-Low mileage full cosmetic restoration back to factory new.
1984 GL1200 Standard model in showroom condition-two owner bike.
1984 CX650E Restored summer 2017 - a rare Eurosport model-excellent one owner bike.
77Gowing
Re: Help with keys
Post by 77Gowing »
Flying900
Thank you, thank you!!!!!!
Yes, like I said I'm a foolish foolish man.
Awesome!
77Gowing
77Gowing
Re: Help with keys
Post by 77Gowing »
No problem removing my gun fighter seat.
The JIS screws are stuck too tight for my jis screwdriver.
Will try my impact driver in the morning.
There's always something.
I don't think I ever took that part off. I never torq the crap out everything.
I know better. But as they tell me here often I'm ham fisted.
Will get some penetrating oil on it for a day or two.
Thought about heat but too close to the tank.
Thanks again fellas.
77Gowing
Re: Help with keys
pidjones
Re: Help with keys
Post by pidjones »
77Gowing wrote:No problem removing my gun fighter seat.
I bought JIS #2 and #3 - 1/4" drive hex bits (by Motion Pro) from Amazon. I use the #2 in a standard screwdriver handle hex bit diver, and the #3 in a 3/8 tee handle with 1/4 hex adapter. You can get a lot of torque on the tee handle.
1976 Yamaha RD400c - rolling basket case winter '20-'21 project
1978 GL1000 - winter project for 2020 challenge - SOLD!
2006 GL1800 - the Black Pearl
1979 GL1000 project - to be restored
Ex '79 CB750F rat bike - the Rocket - SOLD!
77Gowing
Re: Help with keys
Post by 77Gowing »
Thanks pid I'm going to do just that.
77Gowing
RIP: cookie
Re: Help with keys
Follow the link the Boss posted and get a couple of spares ....
‘84 GL1200 Interstate ‘R2B6' (Rat to Be 6)
‘76 project .... R2B3 ....
Team 898, Team LTD 993 ....
My Original 'RAT' was an '82 CB900/1100F
77Gowing
Re: Help with keys
Post by 77Gowing »
Yes I even found that I commented way back then.
Sorry to say but I've got no joy. Bought an impact screw driver cobbled up a PZ screw driver and proceeded to impact away. No joy. The driver instructions are not very descriptive so had to try it both ways. Duhhhhhh?
I deserve this you know. I hope da boss is getting a good laugh out of it.
Tomorrow after my post OP I'll pick up a map gas gun and carefully apply some heat. Barring that it's time to get out my drill.
They are really stuck. And I've never had any joy from a manual impact driver.
It just could be that I'm just flat out matched....like that would be hard. Lol
But...........I never give up. Maybe I'll die trying but I have to try anyway.
Now for some good old Irish libation. Triple distilled.
77Gowing
5speed
Re: Help with keys
Post by 5speed »
are you twisting the handle of the impact driver in the direction you want the screw to go after you insert the tip in the screw and before you wack it with a hammer?
1982 1100 std.
77Gowing
Re: Help with keys
Post by 77Gowing »
Dont know at this point...too much Irishshsh libassshun!
Will to morrow.
77Gowing
77Gowing
Re: Help with keys
Post by 77Gowing »
Yesterday I finally got the two cover screws out and tried my luck at opening my shelter via WF's method. I was too excited and tried just a few times no luck.
So I decided to come back later and try again. It took me 10-15 minutes of fishing around plus a couple of retreads of WF's and I got her done in a non hamfisted way.
No joy though keys are somewhere in the abis. This really should be a Carney game.
Can I extract the airbox without pulling the shelter frame?
Btw guys n gals I'm smitten with wrenching and riding my wing.
Don't think there's a cure either even though I'm a clumsy wrencher.
77Gowing
flyin900
Re: Help with keys
Post by flyin900 »
Do you have a service manual downloaded? The air box is an easy removal with a little fiddling with the larger box part which has a drain hose attached for the PVC system that need to be disconected.
The shelter can come off too if needed, unless they have actuall dropped down into the motor area and not the shelter, you should be able to locate them.
Current Bikes:
Liam
Re: Help with keys
Post by Liam »
Kenny the airbox will come off by removing the wingnut at the top, taking out the filter and then you can see the screws that hold the airbox to the plenum chamber.
Your keys are probably somewhere near the coils or on the shelfy thing which is part of the front heat shield.
77Gowing
Re: Help with keys
Post by 77Gowing »
Liam wrote:Kenny the airbox will come off by removing the wingnut at the top, taking out the filter and then you can see the screws that hold the airbox to the plenum chamber.
Thanks Liam
Yes I had already extracted the box cover and filter. Just hope I don't have to do any jiggerypoakery like take the shelter support off. I'm shy but have complete faith I can do this since I did just start out with just a bunch of parts when I began this journey 5 yes ago. Besides I've had the shelter support on & off several times.
Just lazy I guess.
Thanks I'll pull the box off later this morning. The shelfy thingies I think is like a fire wall.
All the best my friend.
77Gowing
