Overflow tube sizes/lengths
Moderators: robin1731, CYBORG, Oldewing, Forum Moderators
wannabridin
Post by wannabridin »
Hello all,
Quick question - does anyone know the ID and length of the overflow tubes on our bikes? I don't have one for the battery anymore (AGM), so I only need the airbox drain, fuel filler drain and radiator (2 pieces).
Thanks for the help!!
wannabridin
Re: Overflow tube sizes/lengths
I suppose I should of just looked first... But a quick parts fiche shows the following (in case this helps anyone else):
Fuel overflow hose from shelter - Honda 95003-27082-30: Vinyl tube, 9x13x820 (9mm ID, 5/16" would likely work)
Radiator to overflow tank - Honda 95001-80001-60M: Bulk hose, 8x1000 (8mm ID, 5/16" equivalent)
Overflow tank to ground - Honda 95003-14001-10M: Vinyl bulk hose, 6x9x1000 (6mm ID, 1/4" would likely work)
Air box breather - Honda 17278-371-000: Unknown at this time, need to measure my old one
