My FJ1200 saga..so far
Posted: Thu May 06, 2021 3:02 pm
So I learned on the fj forum that the petcock coming apart is a big issue on these bikes. Like burn your house to the ground bad. they have a 90 degree elbow on them that when it fails, falls out of the petcock and gas pours all over your hot engine. Someone lost their house because of it.
So I pull the tank to check mine and that is where the "WTF" saga begins..
The first pic is the petcock with the elbow facing the camera. Mine will spin but won't come out. The accepted fix is to "safety wire" it by wrapping wire around it and the body of the petcock to prevent it from falling out.
The second pic is how the fuel line was run by whomever was there before me. To the left in the picture is a huge white sticker showing the proper routing for the fuel line.
They ran it like that because they put the petcock in backwards..
See the smaller hose below the fuel line? It's the vacuum line for the petcock. Ya..it wasn't hooked up.
But wait..there is more. I pulled the plugs to check their condition. This was the first plug I removed..
The other three had a "better" gap..which is kind of irrelevant considering they were champion plugs and the wrong ones for this bike.
How it even started is beyond me.
