Stuck idler bolt
Moderators: CYBORG, robin1731, Oldewing, Forum Moderators
MikeNTexas
Stuck idler bolt
Post by MikeNTexas »
I’m changing the belts on the 76 and one of the bolts that holds the idler on is seized in the block. It turned about a 1/4 of a turn then got tighter. I fee that if I keep going it’s going to break. Any suggestions on how to free it up?
1975 GL1000 (it’s a keeper)
1983 GL1100 Custom (sold)
Sidecar Bob
Re: Stuck idler bolt
Post by Sidecar Bob »
Spray some PB Blaster on it, let it sit for a while to work its way in and then work the bolt back & forth within that 1/4 turn to work the penetrant between the threads farther until it moves more.
Mr. Honda ('83 GL1100/Dnepr) summer New Engine Thread
salukispeed
Post by salukispeed »
Lots of patience and PB and back and forth. some like other rust busty stuff but PB is usually a reasonable choice. If you have not tried anything yet I and some like Kroil even better but time and patience, Once you force it in frustration it is broken and then you are in a real pickle.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
MikeNTexas
thanks guys That did the trick. Got it out without pulling any threads. Cleaned up the corroded bolt and ran a tap in the hole and it runs in freely now.
Sidecar Bob
If the bolt's threads were rusty that means that the sacrificial zinc coating is used up and it is time to replace the bolt so it doesn't happen again.
flyin900
Post by flyin900 »
It is also a best practice to use an anti seize on any bolts while you have them out, as the galvanic corrosion between the aluminum and steel/zinc plating on the threads, which is usually long gone now. I find many bolts and JIS screws threads are covered with a white gunk along with rust from 40+ years of age.
Current Bikes:
1981 GL1100 - Standard model - Sept 2018 cosmetic refresh, nice original condition.
2 X 1983 CB1000 Custom - Both low mileage with full cosmetic restoration back to factory new.
MikeNTexas
I use anti seize on all steel bolts that screw into aluminum.
Sidecar Bob
That's nice but it won't protect like a layer of zinc.
Kingpin06
Post by Kingpin06 »
I use the spray on zinc, and anti seize.
Sidecar Bob
As long as it is something like this and not a zinc bearing primer
https://www.3mcanada.ca/3M/en_CA/p/d/v000159473/
