little question
Moderators: CYBORG, robin1731, Oldewing, Forum Moderators
Paola Zago
little question
Post by Paola Zago »
Hi all, I collected a small stock of new spare parts in the original packaging for Honda Gl 1000 from ebay, but among these I found 4 unpackaged parts, two definitely not original bearings and two rubber rings. is it possible to know what parts they are exactly so that they can be cataloged?
one bearing measures 52mm externally with 20mm bore, the other 47mm with 20mm inner bore.
thank you in advance
Old Fogey
Re: little question
Post by Old Fogey »
There will be a number on the bearings, like 6005 for instance. Easier to identify them by that.
Paola Zago
Re: little question
the larger one has the code: 6304-2RS, the smaller one 6204-2RSH
Paola
pidjones
Re: little question
Post by pidjones »
Inner and outer rear wheel bearings: https://www.partzilla.com/catalog/honda ... rear-wheel
1972 Triumph T150V Trident rescue - in sad shape
Old Fogey
Re: little question
Post by Old Fogey »
6304 is 91002-371-000 also used on the crankshaft and gearbox mainshaft. Neither use the rubber seals, they just pull out.
Re: little question
That big rubber seal almost looks like the one in the end of the swingarm where the final drive bolts up??
Paola Zago
Re: little question
hi, thanks to everyone for the answers, I have clearer ideas.
Paola
