Timing after head install
Posted: Thu Sep 16, 2021 4:20 pm
Hello once again!
Rounding the corner on finishing head gaskets on my gl1100.
Getting ready to put belts back on.
So, if I understand this correctly:
I've set the pistons 90 degrees down as to not interfere with valves,
Cams and cradles in place, I should put belts back on as if it was a normal belt replacement EXCEPT for setting TDC.
I should adjust pulleys to their proper marks, install belts, then set TDC afterwards, then do my valve adjustment? Do I have this correct?
Please advise.
Anyway, thanks in advance !
Please advise.
