Page 5 of 6
Re: The Aspy Project
Posted: Sun Aug 04, 2024 6:33 am
by CYBORG
Thanks. I have alt. on both my 78, and my 84. I think I might have to increase the size of the pulley's on thr crank so that they charge at idle. Now it's 2500 rpm and above
Posted: Sun Aug 04, 2024 11:33 am
by Track T 2411
CYBORG wrote: ↑Sun Aug 04, 2024 6:33 am
Most all the threads concerning this conversion seem to have good results with the 4 inch pulley. I'm quite pleased with the quality of pulley I purchased. A bit of a wait for shipping, but I really didn't find any other source for one that didn't require a bunch of spacers, collars, etc. One M12X65-1.25 bolt, three or four washers, and we're good to go.
Here's a link if you're interested...
https://www.rdgtools.co.uk/acatalog/4-- ... tion-.html
Posted: Sun Aug 04, 2024 5:15 pm
by CYBORG
Thanks for the link
Posted: Sun Aug 04, 2024 5:49 pm
by Track T 2411
You're most welcome!
Posted: Sun Aug 04, 2024 6:24 pm
by Track T 2411
Posted: Sun Aug 04, 2024 6:50 pm
by Track T 2411
The radiator fan and assorted electrical goodies should arrive today and/ or tomorrow. I should be working on the alternator brackets, but it's just too flippin' hot! The weekly forecast is calling for a bit of a cool down, but between appointments and to-do chores time slots are filling up fast!
Posted: Sun Aug 04, 2024 7:09 pm
by Track T 2411
- 1722811934893641071139783460436.jpg (201.34 KiB) Viewed 314 times
- 17228124834461993698530061725053.jpg (273.48 KiB) Viewed 314 times
Happy almost birthday to me! Everything except the auxiliary fuse block arrived as I was making the previous post... except for some sundry fasteners, I should have everything I need to complete this stage of the Aspy project!
Posted: Mon Aug 05, 2024 6:58 pm
by Track T 2411
- 17228974753441466469657212227620.jpg (224.3 KiB) Viewed 284 times
- 17228975248172692790082974010460.jpg (186.92 KiB) Viewed 284 times
My totally half-a$$ed clearance/ travel check. I know it's not very clear, but it looks like with the current setup I would have about two inches of travel before fender meets fan... probably not acceptable. I'm not sure if I want to try compressing the forks using ratchet straps, or if there might be any other options.
Posted: Mon Aug 05, 2024 7:34 pm
by Track T 2411
- 17228987917272803007825419125449.jpg (286.21 KiB) Viewed 277 times
- 17228990080723437076016518502478.jpg (267.5 KiB) Viewed 277 times
Comparing the coverage... The new fan is a 10 inch, and the overall width is 1/8th inch wider than the OEM radiator 'grille.' Blade to radiator distance is nearly identical between the two.
Options seem be: move the fan up on the radiator, modify the shroud and/ or the radiator side support, a combination of the two, or try a smaller diameter fan.
Moving the fan up seems the simplest, so that will be my next mockup...
Posted: Mon Aug 05, 2024 9:55 pm
by ritalz
I would be tempted to ratchet the forks down to see how close it comes. I do think it will be too close for comfort just by the pictures.
Posted: Tue Aug 06, 2024 10:38 am
by Rednaxs60
The front fork springs are probably original, and as such, soft/weak. Recommend an upgrade to a straight rate spring such as those at Sonic, and get the 1.2 kg/mm, will improve front end handling and minimize front end dive.
I use an 1800 rad fan. Still a tight fit but no need to modify. You only need a 1/8" space between rad fan and pulley to replace/change alt belt if needs be.
You can get a water pump spacer kit, Moroso Water Pump Spacer Kits 63611, helps with moving the rad:
- water pump spacer kit install - 2.jpg (89.19 KiB) Viewed 242 times
Posted: Tue Aug 06, 2024 11:12 am
by Track T 2411
Ernest, I just finished servicing the forks and replaced the original springs with a set from RaceTech, lol. I'll see what specs I can find on fan options after I do another mockup or two.
Posted: Tue Aug 06, 2024 11:20 pm
by Track T 2411
- 20240806_182515~4.jpg (97.29 KiB) Viewed 205 times
According to
https://www.motorcyclespecs.co.za/model ... 00_86.html the fork travel for the '86 Aspy is 5.5 inches. The green tape in the photo is 4 inches from full extension, and I used ratchet straps to compress the forks to nearly the point of contact between fan and fender. The gap shown is about 3/4th of an inch, so the travel before contact would be 3 1/4th inches. I will say that the straps were really straining to get it to that point... Will the front really dive 5.5 inches?
I didn't take a pic of the fan coverage, but it's now installed as high as it can go. I would estimate 5/8ths of the fan actually covers the radiator core area.
Posted: Wed Aug 07, 2024 9:08 am
by robin1731
Under hard braking, yes the forks will travel farther than you can pull them down with a strap. I've tied some down pretty tight and didn't get near the witness marks from where the dust seal had reached before leaving an oil film around the fork.
Posted: Wed Aug 07, 2024 11:09 am
by Rednaxs60
On a hard stop, you can bottom the forks.
