Rat wrote: ↑Mon Feb 06, 2023 11:02 pm
That’s a lot of carb buttons …
What he said!!
I received my new FormLabs Form3 resin printer and I already created a new mold with it. I am using a very expensive, high quality resin that is very hard after it cures. It is almost like ceramic or glass so it should hold up pretty good. I am still doing some fine tuning on the mold, but I am very close. I got the plastic injection machine put together and it works great. I have already created some buttons but these still need some adjustments. I will probably be making two different buttons so people will have a choice. The first option will be a clear or nearly clear button and this is made out of PETG. I recommend this button for most people because it will be slightly smaller than the original to make it easy to install. The second option will be a button that will very similar to the original and it will be made out of acetal (POM). This is for people that are highly skilled like Old Fogey and want to do this as a service. Here are a couple I injected with acetal. Getting close...
-Rodger- all it takes for evil to prosper is the want of a few good men to do nothing-Edmund Burke The question is not how much time do you have, it is what you do with the time that you haveGandalf "One of the greatest dignities of humankind is that each successive generation is invested in the welfare of each new generation." Fred Rodgers "it takes 10,000 hours to become an expert" ancient saying
Today, I finished the mold that will be used to make the original replica button. Although it isn't a perfect replica, it is very close, and it should work just fine. It is made of Acetal which is an incredibly strong plastic. I think Honda used the same material. My button looks like the original and it even has the tiny ring on the underside. Zoom in on the below picture and you will see it. This tiny ring presses against a flat rubber sealing ring.
I cut a button in half so you can see the thickness of the plastic. Tomorrow, I will make about 100 of this type and then start working on the second design that I believe most people will prefer because it will be easier to install. Compare my button to the original.
I have a set of 75 carbs with holes in the plastic. I will have to take that off and look at how that fits.... but these would make those carbs useable. now I just need a 75 engine
For testing purposes, if you will send me your caps and slides, I will install new buttons on them and you can report back to the forum on how you think they turned out. All you have to pay is shipping.
