After rear brake rebuild blues
I tried rebuilding the rear master, and caliper on my 77. I can't get it to pump up pressure. I removed the master cylinder and there was no fluid at the line fitting. I placed a finger over the outlet and when I actuate the pushrod there is a slight pressure at the opening. When I rerelease the pushrod there is a slight vacuum at the outlet. It's pushing and sucking lol. I have disassembled the master cyl. and everything looks in place
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
Re: After rear brake rebuild blues
A few things... First, make sure the rubber cup on the inside end of the plunger is facing the right way. The 'cupped' side should face the spring. Second, make certain the tiny 'spooge' hole is clean and clear. It's hard to see, and is right next to the larger hole under the reservoir cup. Third, it helps to bleed just the master cylinder before installing the lines.
- jdvorchak
You were on the right track when you put your finger over the outlet hole. You just stopped too soon. Keep your finger on the hole while you slowly pump the lever. You will feel suction then after a few pumps the fluid will blow your finger off the hole. At that point, keeping your finger over the hole, release the lever and hook up the banjo bolt and fitting. If there was already fluid in the brake line, all you have to do pump it up, hold the lever and open the banjo bolt to release any air in the brake line joint. Do that a couple of times and you should be good either continue bleed or just button it up.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- tomk1960
+1. This is referred to as priming the master cylinder. Once primed, it will take less than 10 minutes to bleed your rear caliper.jdvorchak wrote:You were on the right track when you put your finger over the outlet hole. You just stopped too soon. Keep your finger on the hole while you slowly pump the lever. You will feel suction then after a few pumps the fluid will blow your finger off the hole. At that point, keeping your finger over the hole, release the lever and hook up the banjo bolt and fitting. If there was already fluid in the brake line, all you have to do pump it up, hold the lever and open the banjo bolt to release any air in the brake line joint. Do that a couple of times and you should be good either continue bleed or just button it up.
1986 VFR750F Interceptor
1983 Honda CB1100F Super Sport - Red 1123 Resto-Mod
1978 Honda GL1000
1978 Honda GL1000
