Water pump
Re: Water pump
tory wrote:Robins bolt kit? Is there a link?
I sent you a PM about 13 hours ago. ;)
tory
Re: Water pump
Post by tory »
Good news is, if the pump was leaking, it was not alone. Majority appears to be the missing gasket to the drain plug. Fixed that yesterday. After a good warm up and little ride it seems to have stopped or greatly reduced.
However the radiator does also have a leak. Hard to pin point as the ride must have spray it back. The drops where coming from the stone shield.
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
Don R
Re: Water pump
Post by Don R »
I remember using a variety of tools to reach all of them. Robin is correct, some of them are behind a frame tube and you have to work on an angle. I'm a big fan of my #3 snap on phillips socket head bit. On my little sears battery impact it removed almost every bolt I ever tried it on. Usually the screw comes out and is stuck on the end of the bit. On the ones on an angle I put on whatever screwdriver can fit and smack the end with a small hammer to shock the threads a little and set the tool into the screw head.
