compressons test!
- Brass Member
compressons test!
My 1975 has been sitting since 1988, only 24,000 miles on it.
Soaked the cylinders down and let sit for a week. Then I it cranked over with kickstarter and pistons moved easily. I then tried the regular statrter. Cranked perfectly and strong. Everything I've found while weathered has been in good shape. Took apart every wiring connection and cleaned and lubed them. Amazing part is they came right apart and I broke none of them! While it was outside when I got it, Im thinking it spent its long sleep ina garage somewhere (I bought from original owner).
Did compression test and got between 110 and 140 on all of them. I'm thinking I'm solid and once I get it running the PSI will come right up to spec once rings get totally free and valves are adjusted.
Prior to this I was about 90% that it was worth bringing back to life but now I'm going for it with what appears to be a solid powertrain.
1975 GL1000 built 2/75
24,000 miles - not run since 1988
Frame GL1001751 Engine GL1E1001756
Price? $100......
Price? $100......
Re: compressons test!
set all 8 valves lash clearances at 0.006"takehikes wrote: ↑Tue Mar 28, 2023 10:55 am My 1975 has been sitting since 1988, only 24,000 miles on it.
Me Too!!
October,2017 BOTM
October,2017 BOTM
Just one winter and my compression checks were disheartening, but a couple hundred miles and they were good.
See gltrikers posts on the 0.006” lash as suggested by him, Mike Nixon and others.
'tis Mike Nixon's advice to increase valves' lash clearance to 0.006". Why do I push it so often? It works.
read it here: paragraph 3-Spec cylinder compression
https://ngwclub.com/forum/viewtopic.php?f=54&t=63468
Me Too!!
October,2017 BOTM
October,2017 BOTM
Also did you have the throttle wide open? Makes a really significant difference.
- Brass Member
PLugs out, throttle wide open.
Price? $100......
Price? $100......
Here I am again, fill it with good clean gas … ride 200 miles … fill it with good cle …
- NotSoLilCrippseys
Takehikes: Start a build thread over in Projects/Restorations (or customs, if that's your goal).
Members like me like to see what's up. And photos are wonderful.
A '75 with 24k in ok (or better?) shape for $100. Nice deal.
I feel like I'm getting teased. And I'm not the only one eager to see what she looks like and how she's coming along.
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
Sold
- Brass Member
I will start a build thread. Thanks
Price? $100......
Price? $100......
Rode lots on bikes in the 120 range. Most really well kept are in the 150s.
My NOS crate motor, was 165, highest I have ever seen.
And yes , plugs out, battery happy, choke off, throttle wide open.
Interference engine, so while belts do not help compression, those aged ones must be replace soon, or you will be looking for another engine. Perhaps preaching to the choir but...
On my 76 Red bike that I bought new, I tested and found the compression in that brand new bike ranged from 135psi to 145psi. I raised cain with the service dept where I had bought it because the manual states it should be 171psi, we argued about that for a long time before I finally accepted that they just don’t have the advertised 171psi. Only ever seen one that had that, a 78, but that’s it.
Mine maintained that cranking compression for many years until I milled .040in off the heads and advanced the cams to +4 deg and then it would check at between 195 +205psi. But just a couple of weeks ago I rechecked the compression looking for a problem and found that they all ranged between 155 & 165psi. I was ok with it because they were very consistent between the 4 cylinders. My bike does run very sweet except for the occasional popping out the exhaust at idle. The compression test along with a leakdown test showed my motor is sound and the problem has to be in the Dyna ignition or the carbs, we’ll figure it out, once the weather warms and dries and my recently repaired knee heals.
I do believe that my bikes compression will improve if we ever get warm, dry weather & me healthy here to where I can put some miles on it. I do believe that your’s will improve with the more your ride it, but if it doesn’t and it doesn’t just blow all kinds of smoke, just ride it and enjoy it ,,,,,, after you change the belts !
I have a good friend who also has a 76 and for years has tested with really low compression on several cylinders, like around 80 psi or so, but that bike is one of the sweetest running GL’s you’ll ever find, it’s truly a sewing machine motor. So on yours just get the valves and ignition set up right, good sync on the carbs and just enjoy your ride ! These are great/fun bikes ! Oh,,,, and change your belts !
I've been wondering about this for a while now: how aged is "aged"? The '77 I resurrected in 2007 got new belts then, but I've only put a few thousand miles on it since because, other bikes. Sits in a warm garage. Do you think the belts go bad from sitting, so, change every 15 years? Every 10? Five?Fred Camper wrote: ↑Wed Mar 29, 2023 8:35 am Interference engine, so while belts do not help compression, those aged ones must be replace soon, or you will be looking for another engine. Perhaps preaching to the choir but...
Some say 5, but I do 10 years if miles are low. Kind of a roll of the dice if you go 20 years, you might do fine.
Compare the cost of belts and the installation to the cost of bent valves and rebuilding a head.
Every five years is good/cheap insurance.
