Water pump leak. Again
5speed
Re: Water pump leak. Again
Post by 5speed »
Steevensi wrote:
5speed wrote:did you change this seal and the o ring around it?
is this picture from an 82? I,m pretty sure the pump doesn't look like that...
But anyway, I changed everything that could be changed when I reassembled the front end of the engine.
Yes. 82 1100. What you are seeing is the oil pump. The shaft for the water pump goes thru that seal and is driven by the oil pump.
http://shop.westernhonda.com/fiche_sect ... fveh=13033
#25 is the seal, #29 is the o-ring.
Steevensi
Post by Steevensi »
ok ok.
Not sure if I changed this one...
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1982 Suzuki GS750 in boxes
5speed
Post by 5speed »
I've never ordered a gasket, o-ring kit..I always ordered the parts individually from honda..
if the kit doesn't include that seal and o-ring then it would be extremely easy to skip replacing them.
Steevensi
Post by Steevensi »
Well I think we found the problem...
The seal is there but the oring is nowhere to be found.
And it’s not attached to the water pump, I checked.
Well, off to the dealer..
Thanks!
The Black Bike
1982 GL 1100
1980 Suzuki A100
Steevensi
#20
Post by Steevensi »
Not there
The Black Bike
1982 GL 1100
1980 Suzuki A100
wingrider
#21
Post by wingrider »
Yep, that’ll leak.
5speed
#22
Post by 5speed »
be extra careful to ensure your neutral safety switch lines up with the notches when you put the trans cover back on..ask me how I know. :oops:
#23
did I mention O-ring :twisted: anim-cheers1 shakehands :-D
5speed
#24
Post by 5speed »
rcmatt007 wrote:did I mention O-ring :twisted: anim-cheers1 shakehands :-D
I asked him if he replaced them before you mentioned it..
Image :mrgreen:
Steevensi
#25
Post by Steevensi »
5speed wrote:be extra careful to ensure your neutral safety switch lines up with the notches when you put the trans cover back on..ask me how I know. :oops:
Will do thanks.
The Black Bike
1982 GL 1100
1980 Suzuki A100
toomanybikes
#26
Post by toomanybikes »
Oil now leaking out the weep hole on my recently resurrected '81, therefore I'm commenting so I can easily find this thread and avoid starting a duplicate thread.
And the pics on Octane's early thread are no longer accessible
Asheville, NC, USA
Stable as of 06Mar25: '19 Triumph Scrambler XC, '22 Moto Guzzi V85TT, '99 Honda Valkyrie, '81 Honda GL1100, '80 Suzuki GS850G
#27
oil can leak from three sources. O-ring n the pump, seal on the pump and the crush washers where the pump is bolted on. Coolant from two sources, O-ring on pump and front seal
#28
toomanybikes wrote: Fri Apr 23, 2021 12:00 pmSNIP
All fixed here viewtopic.php?f=22&t=6863&p=54053#p54053
toomanybikes
#29
Whiskerfish wrote: Mon Apr 26, 2021 4:27 pm
Thanks. Now bookmarked and gasket kit ordered. I'll dig in this weekend.
It probably happened after I tightened down the coolant pump to fix a small leak, which may have damaged other internal seals leading to the oil leak.
Asheville, NC, USA
toomanybikes
#30
rcmatt007 wrote: Mon Apr 26, 2021 3:05 pm oil can leak from three sources. O-ring n the pump, seal on the pump and the crush washers where the pump is bolted on. Coolant from two sources, O-ring on pump and front seal
there does not appear to be any coolant leaking from the weep hole, but i'll replace the main oring anyway.
Asheville, NC, USA
