Neutral switch
Neutral switch
Hey all, I'm putting a 81 1100 engine into a 83 aspincade 1100. Everything seems fine except the different neutral switchs. The 81 is a couple wires and just for neutral. The 83 has the 6 wire harness that goes in by the oil filter. It controls the neutral switch and has a wire for each gear to show up on the digital dash. The harness won't crossover to the 81 engine so I'm guessing I'm just going to loose this on the dash, which I'm ok with. Any thoughts???
- vanillagorilla
Re: Neutral switch
You can swap the front transmission / water pump covers. And all will be right.
You also have to swap the sensor connector on to the shift drum.
And viola, you have thesame features.
Never loan out your wife or bike, you can throw a rod in both of them!
77 GL1000 Bored out to 1100 w/single carb conversion. "The Purple People Eater"
2001 GL1800
78 GL1000 Black #096
74k/75f CB750/836 project
78 Honda Hobbit
78 GL1000 just acquired 7-14-13
79 GL1000 got with this one ⬆
2001 GL1800
78 Honda Hobbit
- 498 Views
Last post by BikeMaine
- 17 Replies
- 1394 Views
Last post by tlbranth
- 7 Replies
- 484 Views
Last post by CYBORG
- 6 Replies
- 840 Views
Last post by rcmatt007
- 6 Replies
- 190 Views
Last post by Dirty Dave
