Electric fuel pump
Electric fuel pump
I've decided to do the electric conversion on Nora. Just have a few concerns to work through before she goes under the knife again. What is necessary to keep the pump from pushing too much fuel into the bowls? I purchased a pump which flows 2.5-3.5psi and 35gpm. Does it need some sort of switch to shut it off when the right pressure is reached, or a bypass of some sort? Have never dealt with carburation before and I'm just a little skiddish, especially since every extra day I spend working on this bike means a day I don't get to ride. I've read through tons of posts about these pumps and they all talk about a cut-off of some sort in case of an accident, mounting issues etc, but I haven't seen this addressed.
Happy Cinco de Mayo everyone.
Gator
Gator
Re: Electric fuel pump
Nothing extra needed. You are a tad high at the 3.5 lbs but it should be alright.
Some have used a tip-over switch. Most are adapted from other bikes.
- Placerville
Which electric pump are you using?
This guy. http://www.oreillyauto.com/site/c/detai ... &ppt=C0025 Its a little bulky, but I should be able to hide it fairly well, especially since it is black. For those of you wondering, I did, in fact, consider spraying it with Line-X, but its plastic and I'm not sure what the heat would do to it. Off topic: Is there a best place to buy batteries for these bikes? The Honda shop is wearing me out wanting $80 for a new one. I know I can do better than that.
Thanks again gents.
Gator
Thanks again gents.
Gator
$80 for a battery sounds pretty good. the good ones are $100+. walmart might be a little cheaper
- Placerville
+1 on that. $80 and no shipping? Grab it. I paid close to $100 for a Big Crank. You get what you pay for.
- Lefty
Mister Gasket doesn't sound confidence inspiring but I used the exact same unit to replace the fuel pump in my GL1200. It required a couple of fittings to enable me locate where the original electric pump had been but with only a little bit of work with a round file it fit in bolted into the original holes. Works fine. You won't hear it come on until you engage the starter.
Been riding Hondas since 1964.
Current bikes:
1985 GL1200i work in progress.
2002 CB750 Nighthawk
Current bikes:
Late post. I've been using that pump from oreilys for almost 3 years in our bmw 2002, as a booster
Regulator set on 2.5 no tip over switch, has 2 barrel webber.
So far, so good.
Dave
So far, so good.
Dave
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
You trying to fill your swimming pool? Obviously a mistype I hopeGator417 wrote:SNIP and 35gpm. SNIP
Whiskerfish wrote:You trying to fill your swimming pool? Obviously a mistype I hopeGator417 wrote:SNIP and 35gpm. SNIP![]()
LOL, I didn't catch that. That is a lot of flow.
I have used Mr.Gasket products since I started racing cars in the early 70's....shifters, fuel pumps, spacers, etc. never an issue or any problems. Buy with confidence and ride on.
1977 GL1000
1978 GL1000
1979 GL1000
1978 GL1000
1979 GL1000
To one, a minute is as an hour, to another a lifetime is but a moment, carried away on a wisp of air. I do like them to run on the rich side, but that's still a bit much. Nice catch. Its also supposed to be 42 gph, so I screwed that part up nicely. That's why we have the url feature here on the forum.
Dave, what type or regulator did you use? I've only seen vacuum controlled fpr's in automotive applications.
Gator
Gator
I was looking to convert my 76 GL1000..but just bought an NOS pump for $89 total (free ship).. Last pump wore out after only 38 years with me !
..oh no..he's not here..he's out riding...again...
[url=http://www.nakedgoldwings.com/gallery/Doccs-Ride][u]Docc's Bikes Album[/u][/url]
'76 GL cafe (owned since new)
'02 VTX 1800C
'02 VTX 1800C
- Recycled Roadkill
The old pump wasn't under warranty?docc wrote:I was looking to convert my 76 GL1000..but just bought an NOS pump for $89 total (free ship).. Last pump wore out after only 38 years with me !
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold)
I called the number for the dealer..but seems it was changed.. A lousy 38 years and it fails..
'02 VTX 1800C
'02 VTX 1800C
