Hi guys, takin some time off the wings... goes to powder coat my cb500T wheels, but honda discontinued the bushing, are there equivalents? help?!
or do i give up on powder coat...
70's honda sprocket damper bushings where are they!!!
1977 GL1000, with GL1100 engine and carbs....in progress
1984 GL1200 Ascenpade gone naked...............in progress
1976 GL1000 1200 Engine, 1200 wheels...........in progress
1983 GL1100 Stock, fully functional!
1982 GL1100 ..................................................in progress
1976 GL1000 Stock resto....................... .........in progress
1978 GL1000....Upgraded...Bad cylinder............in progress
1982 CB900, 83 GL1100 rear end, 2006 gsxr1000 front end, 1200 front wheel..... in progress
1981 CB750k Needs attention.... in progress
The more time I spend on here the farther behind I get
- rtccp
- RIP: 1963-2017
Re: 70's honda sprocket damper bushings where are they!!!
Hey M, I have powder coated several rims with the "cushions" still in them ,never had a problem, just mask them off and let them cool down before you use them...np
1983 GL1100 Standard
okay i definitely thought they would melt... and im doing my 81 cb 750 too with the comstars same as the goldwings except sprocket driven and the bushing are built inside of the rim so no way to remove them
I really need the slide hammer bearing puller
- 17 Replies
- 1417 Views
Last post by KYpondman
- 4 Replies
- 687 Views
Last post by Sidecar Bob
- 1 Replies
- 1646 Views
Last post by Chainman
- 12 Replies
- 637 Views
Last post by jdvorchak
