76 gl1000 engine into a 80 gl1100 frame........
Will it bolt right in? What mods would be involved to make it fit?
Why?
because I have a good 1000 engine and a 1100 wing that needs an engine.
Thanks.
Engine swap - will it fit?
- dontwantapickle
Re: Engine swap - will it fit?
My guess would be yes. But if you have both already, take a few measurements. Even if there are a few minor changes needed , can't be to hard.
It’ll fit no problem!
Only thing I can think of is ignition setup. You can use the 1000 ignition, but a rework of 1100 ignition. Coils will be too low resistance for the 1000 system. I think the 1980 had very low ohm coils. An additional ballast would probably make them suitable. I believe the carb linkages will bolt up to the 76. It will strain a bit more to take off from the lower gearing of the 1100 final drive, 3.1 vs 3.4.
I've had a '79 engine in an '83 bike for 21 years. The engine bolted in exactly like the original but the 1000 has points and the 1100 transistor ignition so I had to remove the ignition units, add a couple of generic automotive condensers and figure out the wiring. The '83 coils are the same resistance as the 1000 coils so I didn't have to change them but IIRC, Eric is right about the low resistance coils on earlier 1100s.
Re ballast resistor, my 1100 coils had a ballast resistor like the 1000's but the 1100 doesn't short the ballast when you press the Start button like the 1000 does so it always had to crank a bit longer than a stock bike. A few yeas ago I converted to Dyna S ignition (which eliminated the need for condensers) and it needed to crank even longer (probably because the Dyna draws a lot of current). A couple of years ago I replaced the original coils with GL1500 coils, which don't need a ballast resistor and after that it started very quickly.
Re gearing: The combination of 1000 transmission and 1100 final drive yields overall gearing more than a gear higher than either stock bike would be. That was wonderful on 2 wheels because it meant that, at the expense of pulling away a bit less aggressively (no big deal if you aren't drag racing) and having to gear down in town or when passing, it would loaf along at much lower RPM on the highway and the mileage was better too. Unfortunately, it isn't so great with the sidecar so I am in the process of preparing an 1100 engine to restore the original gearing.
- 13 Replies
- 714 Views
Last post by 82aspy
- 305 Views
Last post by Track T 2411
- 437 Views
Last post by milesoffun
- 7 Replies
- 302 Views
Last post by guidowitz
- 11 Replies
- 283 Views
Last post by rcmatt007
