Tire sizing
Tire sizing
Hello, I’ve started looking for tires for my 77 gl1000, and I want to go with a wide rear tire but I’m not sure how wide I should go before I’m losing performance. I want to go with a mid-slim front tire and also need size recommendations for that. I was thinking a 110/90-19 for front and a 130/90-17 for the rear. Thoughts?
Re: Tire sizing
Some brands of 140's can fit but many will not, even if you grind away at the swingarm. Most 130's fit and only a few take a mild grind on the swing arm.
Re: Tire sizing
Thanks for that, if I continue with 130 on the rear, what width would compliment that best on the front? The tires i want to get are Skinko 230 touring master btw
Re: Tire sizing
I run a 100/90/19 on the front along with a 130/90/16 on the rear (Lester 16 inch rim). They work well together. Keeps the speedo closer to correct and not sure if a 110 would rub or not.
Re: Tire sizing
I have 110’s on my cb400 and they have about 3/4 inch clearance from the forks on either side, but I might go down to 100 is it’s that close. Not concerned about fender rubbing because my front fender is off a Kawasaki Vulcan so it already has a custom mount
Re: Tire sizing
The 110/90 on the front of both my bikes fills the fender well very nicely.
On the 78 (with a 76 front end) I am running
Front 110/90-19 ME880 Lester Rim
Rear 140/80-17 ME880 Comstar Rim
On the 75 (with a 78 front end)
Front 110/90-19 ME880 Comstar Rim
Rear 150/80-16 BattleAxe BT-45 on a Lester Rim
Re: Tire sizing
I just had Shinko 230’s put on my 75 gl1000 w stock spoke wheels.
100/90-19 front
130/90-17 rear.
100/90-19 front
130/90-17 rear.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: Tire sizing
Note that wider tires will usually have a negative effect on handling.
My first bike came with tires a couple sizes of wider than specified. I didn't know any better and thought that the handling pretty decent so I replaced them with the same sizes the first couple of times. Around the time I needed tires one spring I read a magazine article about tire sizes that described why wider tires are not such a great idea. While they may look good (if you like fat things, that is), they definitely do not help the handling in any way. Remember that at any speed faster than a brisk walk most of your steering is done by leaning and wider tires simply make it harder to lean. Also, if you install a tire on a narrower rim than it was designed for you will alter the profile, usually resulting in a smaller contact patch than you would have with the stock size (if you don't believe me try pulling the beads of a new tire closer together and see what happens to the centre of the tread). I figured it was worth a try so I bought the sizes listed on the decal. What a revelation!!! What I had thought was pretty decent handling was nowhere near what the bike was capable of.
There are, however, exceptions to the rule. The last tires I had on my 'Wing before I added the sidecar were Kenda K673 Kruz; The mounted profile of the front was triangular so when the bike is upright or not leaned very far it felt like a much narrower tire but as the lean increased the contact patch actually got larger.
Unfortunately, they don't make a 17" rear.
BTW: With the sidecar added my tire needs are completely different so I now run tires with a more square profile.
- 4 Replies
- 311 Views
Last post by Funkdoctor
- 20 Replies
- 491 Views
Last post by salukispeed
- 29 Replies
- 949 Views
Last post by pidjones
- 177 Views
Last post by oldwings 78
