Shift arm spring, a replacement option
Saltspringer
Brass Member
Brass Member
Post #1 by Saltspringer » Tue Jun 30, 2020 1:31 am
Hi, my 1976 GL1000 is now back on the road.
Previously I found that the shift was very harsh and the clutch had a very much on/off action. The clutch issue was solved by carefully following the adjustment instructions; now it is much more progressive and easy to use.
During my first road test I lost my transmission and managed to limp home in third, the only gear I could find. The shift lever appeared to be disconnected from the transmission and when I pulled the front cover I found this spring lying in the bottom of the engine case.
It is part number 19 on this parts diagram.
This is the Shift Spring, Honda part number 24641-371-000 and unfortunately no longer available. The only place I could find that has this spring is CMSNL in Holland (https://www.cmsnl.com/products/springsh ... vrEuOpKjIU) but it is expensive to ship to Canada.
After some searching I found a replacement from Gardner Spring in Oklahoma. The part number is GE030-0237-0750-S (https://gardnerspring.com/product/ultra ... nsion-340/) the picture on their website is not an exact representation of the extension spring, but the specs below it are correct. The price was about $6 for three springs, I bought my springs through McMaster-Carr, but I imagine you could order direct from Gardner.
The top spring is the Gardner spring, the bottom spring is the original Honda spring. Once installed it looked like this...
I think that after 45 years service the original Honda spring just fatigued and the upper loop opened up. The new spring seems to be a direct drop in replacement and has a slightly stronger tension than the Honda spring. I installed it this afternoon and my transmission is now working just fine. I am hoping that this spring lasts as long as the Honda one it replaced.
I will let the forum know if this spring gives any problems in the coming months. Given that these springs are cheap, and the failure of the original Honda spring will leave you by the side of the road, I would suggest that anytime you are replacing a water pump, you swap out this spring out too.
1946 Harley WL45
1946 Norton Model 18
1960 BMW R60/2
1972 BMW R60/5
1973 Norton 750 Commando
1976 Honda GL1000
1981 Moto Morini 500
1960 Triumph TR3A sports car.... in many boxes
ob1quixote
Re: Shift arm spring, a replacement option
Post #2 by ob1quixote » Tue Jun 30, 2020 6:44 am
Nice find! You should post this the the Parts Reference subforum as well.
1979 GL1000
2001 DRZ400
1983 CR480
Post #3 by Whiskerfish » Tue Jun 30, 2020 7:41 am
Nicely done! I will move this.
Saltspringer
Brass Member
Brass Member
Post #4 by Saltspringer » Tue Jun 30, 2020 12:36 pm
Thanks guy's.
For the sake of completeness, the spring that I used is also available through McMaster Carr (part number 9065K171), and appears in their online catalogue at: https://www.mcmaster.com/9065K171
The spring is pretty exhaustively described and illustrated. The issue with McMaster Carr is that they only sell to other businesses and I am not sure how, as a private individual, you are able to purchase their products without a business account.
I ordered through my brother and when the package arrived it was marked "Gardner Spring"
1946 Harley WL45
1960 BMW R60/2
1972 BMW R60/5
1976 Honda GL1000
Pony Ruiz
Post #5 by Pony Ruiz » Tue Jun 30, 2020 1:30 pm
Cool. I will have to remember this.....I mean write it down. :IDTS:
nice collections of motos Salts....
1978GL1000 naked - 39k longest build ever.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
Who is online
