1976 GL1000 LTD
ZanVooden
1976 GL1000 LTD
Post by ZanVooden »
Hi all. So I just recently picked up this 1976 GL1000 LTD for $375 from a guy in Milwaukee. This will be my first wing, but I have spent the last couple years working on cb750 ('78 K and F over on the sohc4 forum), so this will be interesting.
I'll let the pictures do most of the talking, but it does run, not as well as it should, I'm guess it needs a carb sync, timing and a valve job to start.
I am a little concerned as the odometer reads 97,xxx miles and I have no reason to believe this is inaccurate so I'm not sure what I'm in for as far as the engine.
My initial plan is to see if I cant sure up the motor. i.e. new oil and coolant, new plugs, all typical maintenance adjustment. Before I start tearing this thing apart I want to now the engine is still good.
The guy I bought it from said there was originally a vetter touring package on it that was removed, thus no headlight, turn signals, or grab rail.
And yes, it does have GL1100 valve covers on it, but the serial number on the engine checks out as a 76 1000.
So yeah. Looking forward to this one.
My Bikes:
1978 CB750 K8 - Black - Sold
http://forums.sohc4.net/index.php?topic ... #msg620853
1978 CB750 F3 - Black
http://forums.sohc4.net/index.php?topic=84810.0
1976 GL1000 LTD
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=36764
1976 CB750K - Turbo 915cc - Collecting parts...
http://imgur.com/a/3XhYE
2007 Yamaha RS Warrior
http://imgur.com/a/RJRQr
northwood
Re: 1976 GL1000 LTD
Post by northwood »
I am confused by the 1100 motor in a 76 LTD. What gives? Congrats and good luck!
2015 Honda Grom (Soon)
2006 Honda VFR800 "Snowflake"
2007 Honda "Chicken Bacon Ranch" (CBR1000RR)
Previous Bikes:
1975 Honda "ol' Bird Dog" GL 1000 (Gone but not forgotten)
1982 Kawasaki AR80 (The one I will regret selling)
1982 Honda CM450E Not so Project "Connie"
1987 Yamaha Virago XV535
2005 Triumph Daytona 650
ZanVooden
Re: 1976 GL1000 LTD
Post by ZanVooden »
Well its not an 1100 motor. Its a correct 1000 motor with 1100 valve covers... Not sure why... yet.
My Bikes:
1976 GL1000 LTD
Re: 1976 GL1000 LTD
What is the serial number? Is the color black or burgundy?
BearWing
Re: 1976 GL1000 LTD
Post by BearWing »
There's an LTD currently on eBay, for a STARTING bid of $6500.
http://cgi.ebay.com/ebaymotors/Honda-Go ... 3cbc3b5a81
Re: 1976 GL1000 LTD
That looks like a very interesting project.
Be sure to put a timing belt change on your to-do list.
ZanVooden
Re: 1976 GL1000 LTD
Post by ZanVooden »
The serial on the engine is G1E-2035488. I dont have the frame number off hand. The color is blackish or really dark brown
My Bikes:
1976 GL1000 LTD
achmedachmed
My Album: http://www.ngwclub.com/forum/viewtopic.php?f=30&t=34729
Re: 1976 GL1000 LTD
Post by achmedachmed »
NICE!! and that for just $400 Lucky guy!
Are you going to restore it? Keep it as original as possible since only 2000 were made?
I wanted to make my Yellow 76 a Cafe-racer, but now I want it to be as original as possible :P
A forummember here sells the cheapest good quality timingbelts http://www.cascadecycle.com/newhondaparts.htm
Have fun
1976 GL1000 Sulfur Yellow (CPR-mode)
ZanVooden
Re: 1976 GL1000 LTD
Post by ZanVooden »
Well like i said my first order of business is to make sure the motor is in good enough shape to justify a rebuild. If that's the case then im probably try to restore it as much as i can
My Bikes:
1976 GL1000 LTD
Dog Boy
Re: 1976 GL1000 LTD
Post by Dog Boy »
Nice find.
It looks like it's been played with a bit but sounds like you have a handle on it.
Good luck with your project
AL
They call me "Dog Boy"
Can't blame the "PO"
Original owner 76 LTD
Team 993
murrayf
Re: 1976 GL1000 LTD
Post by murrayf »
the engine is the correct one for the bike and is a ltd engine
Our Current Bikes at home
CX650 Deluxe turned out awesome a treat to ride
1983 GL650 naked
1983 GL650 full dress
2 1978 CX500 WHAT????? i like them
1981 gl500 Rachels build
1978 cx500 BIG 650 motor dual 38mm mikunis
1980 cb750 DOHC dual mikunis vance and hines exhaust
1971 cb750 SOHC dual mikunis
1966 cb350 dual mikunis baby 28s
1975 GL1000 owned since new
1977 Gl1000 dual 38 Mikuni carbs New Daily Rider
1976 GL1000 ltd
1983 GL1100 full Tupperware Dual 38 mikunis
1978 CX650 Deluxe my toy Dual mikuni 36mm
Re: 1976 GL1000 LTD
Yes, those look like '76 carbs so seems like the bike is a keeper provided you get compression on all 4. Bet you do.
dbtroudy
Re: 1976 GL1000 LTD
Post by dbtroudy »
It certainly looks like it has the various parts to be an LTD, right frame number, gold rims, chromed parts. Some pvo didn't realize what he had here and played around mixing and matching various parts. If your engine compression test comes out good, you'll have a fun bike to restore. Did you check your carbs to make sure they are all matching numbers?
Don
DBTroudy
Fullerton, CA
'03 GW GL1800 Yellow
'76 GW GL1000 LTD #859
'75 CB200T
ZanVooden
Re: 1976 GL1000 LTD
Post by ZanVooden »
So time for some updates.
For those wondering the frame serial number is GL1-2036968.
So I started investigating the engine and the rest of the bike. Pulled the radiator and the timing belt covers. Belts look good. dont look visibly worn. I will leave them on for now as I try to tune the engine and carbs to prove that it runs well.
Compression checked out alright. I did a first check and got:
#1 #2 #3 #4
120 118 120 140
Added a bit of oil to each cylinder, did the compression check again, and got:
#1 #2 #3 #4
160 160 155 160
So I thought a bit, and the first test I did, the bike had been sitting for a while and figured maybe the issue was just that the cylinders were dry. So I turned the engine over a couple times once in awhile and let it sit, then redid the compression check now that the cylinder wall were lubricated and got:
#1 #2 #3 #4
150 150 150 150
With that I assuming my compression is alright. So I moved on and pulled the valve covers and set the valve lash. Nothing too far off, or surprising there.
Figured I would also check my point gap while I had the feeler gauges in hand. Pulled the points cover and found I have a Dyna S electronic ignition under there. So that threw for a bit of a loop. I have no idea how to set timing with one of these. Coils appear stock still. So I need to do a bit of research on this thing.
Checked the plugs, found three different spark plugs... (2x d7ea, d8ea, and a nkg-r plug) Replaced those all with d8's and set the plug gap.
Regardless, I drained the oil and replaced it and the filter with new. Put the radiator back in place, and topped off the coolant. I drained the gas and put in fresh.
My Bikes:
1976 GL1000 LTD
ZanVooden
Re: 1976 GL1000 LTD
Post by ZanVooden »
It took a bit of playing but I got the bike to start up and run. Smoked like a chimney but that lessen after awhile, so not worried there.
The biggest issue I have is with the carbs currently. It appears that they are set incredibly rich. I could only get the bike to start with the throttle wide open, and there was considerable backfires through the exhaust. At one point I noticed raw fuel dripping from a leak in the exhaust pipe. Also after getting it to start and run, if I let the rpm drop anywhere near idle, it would die, and would start again until I pulled the plugs and dried them off, as they were dripping with fuel. So much so that the fuel would bridge the gap of the plug and therefore the plugs would not spark.
So my next step is to adjust the fuel mixture and attempt to lean it out some and try to dial in the fuel mixture, then sync the carbs, then adjust the mixture and sync once more.
My Bikes:
1976 GL1000 LTD
