Pedro!'s rebuilding projects
hello and welcome back Pedrotq, I'm super happy to hear from you and to see photos and comments of your extraordinary work! truly truly remarkable! Come on Pedrotq, a huge hug!
Paola (Italy)
Paola (Italy)
- Rednaxs60
Fantastic work, and welcome back - quite the entrance. Good to hear about you're out of the woods so to speak. Your rim work reminds me of my early stock car days in the '60s. Dad did a lot of work on rims to make the cars go around the track better. Doesn't everyone have a 12 inch metal lathe and milling machine at the ready! LOL!! Very jealous.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
- Pedrotq
Thanks for the encouraging comments Guys
I could have bought myself a second car or a new bike, but i opted for a lathe and milling machine along with some tooling for them, i don't use them often but when i do its more rewarding.
I have finished gluing the panel into the left saddlebag, just have to fit them and the air pump, then the rear end is nearly done, just have to finish the tail lights.
Awaiting the arrival a newer style airbox then the front end can be put together and i am on the road again
Happy an Safe Riding to All .....
- 101_1409.JPG (257.23 KiB) Viewed 647 times
- 101_1410.JPG (381.73 KiB) Viewed 647 times
Perth, Western Australia.
- RIP: cookie
Just amazing ... maybe everyone should have that white streak down the middle ??
- Pedrotq
Its the pain that goes along with the white streak that may put everyone off ?
Fitted the saddlebags with not much clearance to the mudguard.
- 101_1414.JPG (254.75 KiB) Viewed 612 times
- 101_1415.JPG (232.66 KiB) Viewed 612 times
- Pedrotq
I knocked up a bracket for the air pump, those Nutserts are a great idea.
I also had to make a threaded tube to connect the two air lines together.
- 101_1411.JPG (338.19 KiB) Viewed 611 times
- 101_1412.JPG (306.17 KiB) Viewed 611 times
- 101_1413.JPG (318.74 KiB) Viewed 611 times
- 101_1416.JPG (374.73 KiB) Viewed 611 times
- Pedrotq
The saddle i have been using was off my 90SE (which will be my Naked 90 soon), it is brown in color and does not match the red paintwork, it has a tear and a small cut as well so i bought a new seat cover which arrived the other day.
I removed the old cover only to find that someone has been there before and ground the riders seat down for a stout person, i do not need to put my feet down with a sidecar so comfort is more important, i have to go down to a rubber store and get some sponge sheeting and glue to thicken up the seat to OEM levels.
Happy and Safe Riding to All
- New seat cover.
- 101_1417.JPG (247.72 KiB) Viewed 610 times
- Old seat.
- 101_1418.JPG (334.43 KiB) Viewed 610 times
- 101_1419.JPG (264.44 KiB) Viewed 610 times
- Skinned saddle.
- 101_1421.JPG (267.41 KiB) Viewed 610 times
- The ground down front.
- 101_1423.JPG (213.25 KiB) Viewed 610 times
You may find it hard to find sponge stiff enough to make a good motorcycle seat (we do here). What does work well is carpet padding (called rebond here) that is made of foam that is chipped up and reglued into a random looking sheet. Seems to be perfect for seat foam. 3M 80 spray cement (used to bond headliners in cars) works very well to glue it, and electric carving knife (DON'T use the wife's!) for rough shaping, sanders and grinders for smoothing.
- Pedrotq
Thanks for the advice "pidjones"
picked some up from a carpet store and went to work.
ground the edges a little to give an edge to glue up against, just got to let the glue dry for a day then i can grind the lower edges to smooth them out before i fit the cover.
All the best, Peter
All the best, Peter
- 101_1424.JPG (229.35 KiB) Viewed 576 times
- 101_1425.JPG (245.86 KiB) Viewed 576 times
- 101_1426.JPG (233.55 KiB) Viewed 576 times
- Pedrotq
G'day to All
The second layer of sponge underlay went on today. Give it a couple of days to really dry out then put the cover on.
Happy n Safe Ridin to All
- Middle bit down.
- 101_1427.JPG (262.49 KiB) Viewed 556 times
- Sides on.
- 101_1428.JPG (248.33 KiB) Viewed 556 times
- Glue the edges down.
- 101_1429.JPG (241.73 KiB) Viewed 556 times
- Pedrotq
G'day to Everyone!
I finally got around to fitting the tail light lens to the body using "Mastic D" to seal her of with.
Just got to do the same with the saddlebag light.
Peter
Peter
- 101_1430.JPG (263.58 KiB) Viewed 530 times
- 101_1431.JPG (285.03 KiB) Viewed 530 times
- 101_1432.JPG (185.57 KiB) Viewed 530 times
- 101_1433.JPG (179.82 KiB) Viewed 530 times
- Rednaxs60
Nice job.
Ernest
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
Pedro the Questionable, you are unquestionably talented! Love seeing what you are doing with this 1500, I believe there is nothing out of your reach. Take care of yourself and continue to heal.
- Pedrotq
G'day and thanks for the kind comments
I guess that many of you are in the same boat as me with my 76 GL-1000, the shelter key a different cut to the ignition key.
I leave the key in the shelter lock as when i get home i have to use the remote garage door opener which is kept in the shelter box.
A while ago i scored a set of chrome radio knobs for my GL-1500, i did not fit them as i do not like too much "Bling" also whilst riding in the sunshine too much is reflected into my face and that sometimes triggers a migraine which i then have to pull over and let it pass which takes 20-30 minutes.
I got my shelter key and inserted it into the shelter lock then scribe'd a line where it sticks out, gave it 1/4" extra and cut the head off, filed the edges down to fit snugly into the radio knob, drilled a little hole in the bit that sticks out the lock so the glue has something to hold onto and glued them together.
I never leave anything of value in the shelter when i go out so the chrome knob key stays permanently in the lock, most people don't know the shelter exists anyway.
You could also do this with the ignition key but you couldn't push the key all the way in to lock the steering, but it looks nice.
Stay safe, Peter
Stay safe, Peter
- The pack the knobs came in after i salvaged it from the trash bin.
- 101_1434.JPG (208.68 KiB) Viewed 501 times
- The completed "Chrome Knob Key" which i made weeks ago.
- 101_1435.JPG (103.63 KiB) Viewed 501 times
- Fitted into the shelter lock where it lives permanently.
- 101_1437.JPG (194.88 KiB) Viewed 501 times
- I just inserted it ito the ignition to see what it would look like.
- 101_1438.JPG (259.69 KiB) Viewed 501 times
- 101_1439.JPG (240.37 KiB) Viewed 501 times
- Rambler
Ha Ha, I'm looking for one and you seem to be tripping over many in your garage. You do amazing work.
Randolph, Maine
KC1W
1982 Standard GL1100 … Alas no longer mine.. :(
Would really like to find another GL1100 .. the perfect bike.
KC1W
- 31 Replies
- 1991 Views
Last post by gltriker
- 11 Replies
- 1386 Views
Last post by heraldhamster
- 39 Replies
- 1235 Views
Last post by Fred Camper
