The tale of TWO
The tale of TWO
Well, it started with my desire to find and restore a (as in SINGULAR) GL1000. Long long ago I road a brand new K1 CB 750 out of the showroom (why didn't I keep that to restore!!??) I hadn't ridden in many a year but now I wanted to again........and something special.........something vintage.
So...... I began the search.....
Just north of Dallas, I found this remarkable '76. With 5,600 original miles !! It ran but rough and I trailered her home.
Here's how she looked -
- DSC03130.JPG (183.99 KiB) Viewed 433 times
- DSC03123.JPG (81.84 KiB) Viewed 433 times
- DSC03126.JPG (116.75 KiB) Viewed 433 times
- DSC03134.JPG (136.77 KiB) Viewed 433 times
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
As you can tell, not very rough. In fact, not rough at all. There was a small area on the frame below the rear brake master cylinder where someone had to have spilled brake fluid on the frame and the top of the engine casing is all I needed to touch up. Then there was the usual to completely paint - gas tank, radiator, air filter housing, etc.
Speaking of paint........I didn't have to touch any of the original panels/covers/tank....... just polishing.
But everything else mechanical I went through completely.
- DSC03163.JPG (170.97 KiB) Viewed 431 times
- DSC03167.JPG (120.23 KiB) Viewed 431 times
- DSC03174.JPG (139.25 KiB) Viewed 431 times
- DSC03179.JPG (152.94 KiB) Viewed 431 times
- DSC03193.JPG (70.24 KiB) Viewed 431 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
Pulled the heads.......probably didn't need to but did. Rebuilt the carbs. Stainless steel brake lines. The usual aluminum stripping and polishing. Rims/spokes were absolutely perfect after cleanup. This thing barely got out of the garage!!
- DSC03215.JPG (113.56 KiB) Viewed 430 times
- DSC03231.JPG (188.31 KiB) Viewed 430 times
- DSC03232.JPG (182.96 KiB) Viewed 430 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
Tomorrow...........the rest of the "tale".......
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
- Liam
Re: The tale of TWO
That is a sweet looking LTD. I love it.
- RIP: cookie
Re: The tale of TWO
What a find !!
Re: The tale of TWO
wow..it looks like you just rode it out of the showroom.
1982 1100 standard.
Re: The tale of TWO
+1!5speed wrote:wow..it looks like you just rode it out of the showroom.
Re: The tale of TWO
Thanks for the kind comments......
OK...
So there I was with my LTD and pleased..........but............I absolutely LOVE the candy blue '75's. So cruising around craigslist out and about the grand USA.........one day some few months later...........
Yep.......out of Kentucky......there she was !!
You are NOT going to believe this one. The '76 had 5,600 original miles............well this one had just barely UNDER that!!
I called the number and spoke with the widow of the original owner. She told me her husband bought it new and about a year later had a "scare" on it ..........AND PARKED IT.
I mean literally parked it. The license plate and inspection both expired in 1977.
It was MUCH rougher than the '76 (was exposed to the elements).
So had it shipped here to Austin and this is how she was.................
OK...
- DSC03251.JPG (120.5 KiB) Viewed 407 times
- These wells were full of water when I got it.
- DSC03256.JPG (102.7 KiB) Viewed 407 times
- DSC03272.JPG (126.09 KiB) Viewed 407 times
- DSC03276.JPG (113.6 KiB) Viewed 407 times
- DSC03252.JPG (169.24 KiB) Viewed 407 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
My favorite part was that rats had nested on top of the engine (under the carbs) for a VERY long time. The blue material inside the air filter cover is rat poison that was put in there by the original owner.
The brown color coming down over the engine is stain from years of rat pooh and rain.
- DSC03281.JPG (128.44 KiB) Viewed 406 times
- DSC03321.JPG (104.53 KiB) Viewed 406 times
- DSC03313.JPG (133.47 KiB) Viewed 406 times
- DSC03335.JPG (92.05 KiB) Viewed 406 times
- DSC03342.JPG (123.95 KiB) Viewed 406 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
I learned that now matter how much carb cleaner, wires, brushes, soda blasting you do to carbs. When you REALLY want to clean them. Put 'em an ultrasonic cleaner (with a little dishwasher soap) and watch the "magic" of the puffs of crud coming out all the orifices.
So Randakk kits and video of course it was !!
- DSC03354.JPG (47.39 KiB) Viewed 404 times
- DSC03358.JPG (62.7 KiB) Viewed 404 times
- DSC03360.JPG (143.25 KiB) Viewed 404 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
Wow! As you say, a tale of two! I always find the backstory on people's bikes interesting. I must admit that I've been guilty a couple of times in the past of the 'park it and try to forget it' mentality. Glad you could save it.
Re: The tale of TWO
Those carbs look fantastic!
Re: The tale of TWO
I wanted to see how/if she ran so I put the carbs on, filled up the coolant and gave it a try.
She fired right up and literally purred.
I had removed the mufflers and gas tank and both were rusted trash. (see pictures). So I used a spray bottle for a gas tank and a tin can temporarily for the header/exhaust connection.
- DSC03344.JPG (106.3 KiB) Viewed 403 times
- DSC03361.JPG (182.73 KiB) Viewed 403 times
- DSC03365.JPG (171.36 KiB) Viewed 403 times
- DSC03374.JPG (120.75 KiB) Viewed 403 times
- DSC03368.JPG (88.07 KiB) Viewed 403 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: The tale of TWO
Unlike the '76, this was a (duh) frame off.
So..... stripped the paint frame, painted it, HATED it!!
Everything black....went to have powder coating.
Took the wheels / rims / spokes apart and had the rims powder coated as well
- DSC03400.JPG (229.3 KiB) Viewed 402 times
- DSC03429.JPG (116.87 KiB) Viewed 402 times
- DSC03430.JPG (94.2 KiB) Viewed 402 times
- DSC03469.JPG (134.19 KiB) Viewed 402 times
- DSC03457.JPG (111.41 KiB) Viewed 402 times
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
- 8 Replies
- 310 Views
Last post by rcmatt007
