Just set valves on my 78 CX500. Using procedure in my manual I turned the engine over using the rear wheel. Even with the plugs removed to lower compression this was difficult to do and every time I forced the wheel past the compression my left forearm would bang into the rear shock. Woke up with a painful and nasty looking bruise on my arm. Don't want to go through that again so before reinventing the wheel I thought I'd check here.
Anybody have an easier way to turn the engine while setting the valves?
Setting valves injury
- docfishr
Ride, Fish, Play and Sing
The riding is a wing thing
78 GL1000
78 GL1000
- docfishr
- Q
- BerlinKowgirl
- Lady Winger
LOL! Sorry I had to laugh when I read your post...
When I set the valves on my 78 CX500, I never turn the wheel, I always turn it at the crankshaft. You won't get hurt, and it's so much easier, too...
You should get a rapair manual, that makes all maintainence jobs easier.
Cheers,
Peewee
Cheers,
Peewee
Cheers! Peewee
1976 Honda GL1000 (put in shed, threw away key)
1978 Honda CX500 (the winter bike)
2001 Aprilia SL1000 (daily driver, my pride & joy)
And a bunch of projects not worth mentioning...
Re: Setting valves injury
Which manual says to doo it that way?docfishr wrote:Just set valves on my 78 CX500. Using procedure in my manual I turned the engine over using the rear wheel.
- docfishr
Thanks for the help folks. I knew honda would not have designed it so that was the only way to turn the crank.I was following valve adjustment procedure in the Haynes manual that says " Select top gear and turn the rear wheel in its normal direction of rotation to turn the crankshaft." (pg 37 item #4 second paragraph).
I believe this manual was written by a Brit. Have since acquired a Clymer manual. Much better!
78 GL1000
78 GL1000
