Shelter lock 75-77 models
How to open a Top Shelter on a 75-77 witout the keys.
Remove the seat. Remove the small colored trim piece at the back of the shelter
Using a long skinny straight slot or something similar find the gap at the back of the shelter frame. Insert your screwdriver there.
Gently slide the screwdriver over aginst the spring on the right hand side of the lock mechanism. Once you feel the spring then push the tip of the screwdriver down. It should not take much effort. Applying a bit of pressure to the top in the direction of opening may help.
She should pop right open!!
heraldhamster
Post by heraldhamster »
good one.
H2G2=42
lsgyger
Post by lsgyger »
Slick! action1 action1 action1
Larry
75 GL1000 in various states of repair/restoration
In the Beginning - http://rides.webshots.com/album/560588072GnCGNH?start=0
...and Now - http://rides.webshots.com/album/564150904HcRkSK
lsgyger wrote:Slick! action1 action1 action1
X2
bum
Post by bum »
Hey whiskerfish(chief),
you seem to have all the answers, ok so how do I keep my wife and daughter from hitting me? hahahaha....you might call it wingman abuse!!!! 8)
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
d6500k
Post by d6500k »
OK!...
but since all my tools are in the bag, in the tray, under the locked hatch, that I just closed after fueling with my keys in the place near the fuel cap.....
Just kidden.. really good trick!
Doug k
"The more they tinker with the plumbing, the easier it is to stop up the pipes."
Montgomery Scott
1976 GL1000 LTD
peteybug
Post by peteybug »
O.M.G its no wonder they use to let him work on air craft lolol action1 action1
He's a noted car thief...
b2948kevin
Zinc Member
Zinc Member
Post by b2948kevin »
Major props for this one, Whiskerfish! My lock just fell apart as the whole barrel came out with my key. I searched the forum, and 5 minutes later I have a workaround. Thanks!
-Kevin
77 GL1000 26,000 Miles
82 Shovelhead Rigid Chopper
78AZWing
Re: Sheter lock 75-77 models
Post by 78AZWing »
On my '78, if you push the lid at the lock end to the right, the lock will disengage. You have to really mean it, though.
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
Hal
Post by Hal »
It worked for me! I thought my keys were inside, but sadly they weren't.
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
2002 Caterham SV 220 Evo (4 wheeled motorcycle) :mrgreen:
Hal's Nalbum
taylorsel
Post by taylorsel »
That's also a good trick if you don't close your gas cap and it jams. I did that once and thought id never get it open.
STEVE LOGAN, 1979 GOLDWING, 1978 GOLDWING, 1976 GOLDWING
77Gowing
Post by 77Gowing »
Great tip WF.
Your pics and written description make it very clear to understand, so I expect even I can do this.
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold :crying)
2014 Yamaha 950 V Star (sold)
Boss, this will be easier to find as a reference if the title is fixed to Shelter not Sheter.
ericheath wrote:Boss, this will be easier to find as a reference if the title is fixed to Shelter not Sheter.
lolol lolol lolol lolol lolol lolol lolol lolol
Ok i guess action1 action1
