This set has not been out in the real world yet ... did a set for my sons 85 shadow a few years ago and they are still looking good. Did his bike in barracuda orange.Hoosier Daddy wrote:Nice job! How long have they been in use? No problems once in use I take it...
My "outside the Barn" find GL1100.
- Hoosier Daddy
Saturday I packed up the frame and other parts into the Jeep and took it to work. Settled on some black enamel that has a catalyst (hardner) you add before painting. I let it hang in the booth over the weekend then brought it all back home.
Shiney parts are a real motivator!
- Hoosier Daddy
Thanks Neil... funny you mentioned Barracuda Orange, I'm thinkin "Plum Crazy" and silver for the shelter and side covers.
- mdbauer1962
H-Daddy: The project looks like it has hits its stride ! Your in the home stretch now. I'll be where you are this next winter. Every nut and bolt......
Mark Bauer
1980 GL1100 Std w/Vetter Package
First Stage - Make her look good and run good - COMPLETE
Second stage - Customize - Scheduled for winter 2009/10, moved out to 2010/11 'cause I finally found my '83 donor bike
- Hoosier Daddy
*UPDATE* (Gotta keep my build thread going so you guy's don't think I'm slackin!)
Spent some good quality time on the scooter today. Hmmm, my name is Scott, people occasionally call me Scooter, maybe I'll name it "Scooter's Scooter"
Anyhoo, A while back I polished the front forks and installed the triple tree, I have been working on the wiring harness, darn glad I labeled all the connectors and took pics as I disassembled. Made it much easier to re-route.
Today I got the rear wheel bearings removed, cleaned and repacked. Rear rotor refaced and installed. Lubed the final drive with the High Moly grease as recommended and reassembled the rear end.
I either clean-n- polish, or blast or Naval Jelly, then repaint every nut and bolt or small widget along the way. Cracked a cold one, stood back and took a look and I likes what I see so far.
Pay no attention to the “beast on the left, she’s my “donorâ€
This is one thing a lot of folks take for granted. One mistep with that harness can cause a bunch of trouble. I once routed one under a support instead of over it and it cost me the better part of a day to fix it. She looks like she is coming along very nicely!!Hoosier Daddy wrote: I have been working on the wiring harness, darn glad I labeled all the connectors and took pics as I disassembled. Made it much easier to re-route.
- Hoosier Daddy
Thanks Guy's... means a lot coming from you 3 guru's!
Nahhh She's gonna be Octanes Bulldog's younger sisterSo, you're going for a full-blown concours restoration?
- Cookie
- RIP: 1950-2011
I just notice my breather hose ended up under my gas tank. I'll trim it off and run another rather than pull that sucker again. Maybe that's why it went in hard.
It's hard to remember where all that stuff went later.
