MY PROPANE POWERD WING
Hydrocarbon Rocket
RIP: 1976-2013
Post by Hydrocarbon Rocket »
HEY ALL. I LIVE IN TENNESSE AND I JUST BUILT MY 84 1200 ASPENCADE TO RUN ON PROPANE. I'M A MANAGER AT A LOCAL PROPANE FACILI TY SO, I LOVE PROPANE AND PROPANE ASSECCORIES.
I'VE BEEN TRYING TO REGISTER ON HERE FOR A DAY OR TWO AND FINALLY GOT THRU ON MY 2ND REGISTERED NAME.
ANYWAY HERE IS SOME PICS OF MY BUILD AND PRESENT CONDITION. I DON'T NORMALLY TAKE ENOUGH PICS AND THEY ARE CERTANLY NOT GOOD. I STILL HAVE ALOT LEFT 2 DO. I STARTED THIS 2 FRIDAYS AGO AND HAVE ONLY GOT TO WORK ON IT ABOUT 18 HOURS. FOR NOW I'M GOING FOR FUNCTION BEFORE BEUTY AS I NEED TO TAKE A TRIP ON THIS THING IN THE LAST WEEK OF AUGUST.
O YEA, IT WILL RUN 92MPH IN 2ND GEAR. ITS GOT A DAKOTA DIGITAL TACH/SPEEDO CALIBRATED WITH MY GPS. DON'T KNOW HOW MUCH FUEL MILAGE IT'LL GET YET. TANK WILL HOLD 8 GALLON. IT SHOULD GET AT LEAST 36MPG.
BEFORE I RUINED IT
AFTER I RUINED IT
Take heed therefore that the light which is in thee be not darkness. Luke 11:35 KJV
http://ngwclub.com/forum/viewtopic.php?f=16&t=28320
RIP: 1950-2011
Re: MY PROPANE POWERD WING
Post by Cookie »
Now that's a chuckle, one of my friends was thinking of doing something similar with a sidecar for the tank.
JBz
Post by JBz »
cool. i thought about that the other day. My tanks are the dual squat ones for the trunk of a car but sold my mixer and valves and said na I got other things to do. Time to turbo it next lolol . how heavy is that tank when full. ?JB
Papa Bear
Post by Papa Bear »
Your name isn't Hank is it? LOL!
Papa Bear
Keep your head on a swivel and your eyes open!
Current bikes: '78 Wing with '76 false tank, '76 Wing (GLzilla) with 1200 bottom and 1000 top end, '82 GS850 beater bike. '84 1200 project motor.
Previous bikes: '72 Yamaha 250, '76 Kawi KZ400, '62 Triumph 650 Bonnie, '74 Triumph (Chopped), '78 Kawi 750 Twin, and '76 GL.
Oldewing
Secretary
Secretary
Post by Oldewing »
Papa Bear wrote:Your name isn't Hank is it? LOL!
I must admit, that was my first though........
Cool application though, how safe is the tank? What carb change?
Placerville
Post by Placerville »
92 MPH in 2nd gear? :shock:
Placerville - 1976 Yellow
Survivor - BOTM - May 2011
New and Confused ?
Push the Big Button
Hydrocarbon Rocket
RIP: 1976-2013
jbz wrote:cool. i thought about that the other day. My tanks are the dual squat ones for the trunk of a car but sold my mixer and valves and said na I got other things to do. Time to turbo it next lolol . how heavy is that tank when full. ?JB
55lbs full.
1CrazyMoFo
Post by 1CrazyMoFo »
What a Gass, well done!
The truth about Ape Hangers, yes they are very slimming.
Hydrocarbon Rocket
RIP: 1976-2013
27 times more puncture proof than a common gasoline tank with no vapor or vents to worry with.
I kept the original carbs for the throttle body, removed the breather box top and capped, removed the metervalves from the center of the carbs. With all top caps removed I built a box to adapt 1 propane mixer per 2 carbs. The center section is left open so that 1 mixer will still run both sides if neccecary. Keeping both sides open also help with tuning, bout the only thing i need to put in sinc is the vacum on each throtle body.
Hydrocarbon Rocket
RIP: 1976-2013
Placerville wrote:92 MPH in 2nd gear? :shock:
Yes, 92mph in 2nd gear! Is 11000rpm to much for a wing engine?
Hydrocarbon Rocket
RIP: 1976-2013
No, but that is one of the most realistic life like shows I've ever seen. Seems like you know someone just like each caracter. I don't watch it anymore cause it says too many bad words.
Neil
Post by Neil »
This is a bit much for an introduction although welcome to NGW.
Moving this to Underground Customizing.
Papa Bear
Post by Papa Bear »
No, I wouldn't think so. They have pretty heavy duty crankshafts and rods and with the mechanically adjusted valves, they should be able to handle it.
Papa Bear
JBz
Post by JBz »
looks like a 1200 to me with the hydraulic valve lashers . I think the factory redline on the 1200 is around 7500 rpm-8000 rpm . 11000 rpm thats up there. jb
I wouldnt run that high very often. Stock valves are pretty heavy and old stock valve springs are not made for that. It is a pretty cool project though.
