well my '76 i purchased,hasn't run since '98, nice 24k bike,
last known-
carbs done twice,2 diff people,ran like crap,,,
DOT 8 brk fluid,exploded masters,mushy hoses,ceased calipers.
All brk parts off being rebuilt..
NOW the carb,
purchased a manifold and holley from Sunnbob,
carb needs rebuilt,manifold freshly power coated,
what the heck,stole battery from the ltd,bolted up the
the new to me stuff,hit the button and it runs,some cable
idle screw adjmnt,funky idle,,, OH NEED TO ADVANCE TIMING,
geez,this thing is responsive,seems to idle well(maybe a little high)
(goofy,lazy tach)not sure of rpms..
I wanna ride it !!!!
D--- no brakes,flintstones,
HOW BIG ARE MY STONESSS ?
should I or shouldn't I
single carb ' holley
Tom
1976 LTD #276
1976 BLACK VETTER (soon to be naked)
1978 Naked(soon to be dressed)
1983 750 sabre(1476 miles) next project
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
Re: single carb ' holley
I thought that Holley had been rebuilt?
May have been,don't remember,that makes it really good deal,bolt on and go..
Had to mod the cable brkt a touch to clear frame gusset.
This morning before work,no choke,2 twists,fired and almost idles perfectly ,,no choke
and guessin' at timing..
By the way,,Sunnbob
thanks tons
great deal
By the way,,Sunnbob
thanks tons
great deal
Tom
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
A couple pics
Tom
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
bump
Tom
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
1976 LTD #276
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
- Cookie
- RIP: 1950-2011
I sure do see easy starting with mine. Get those brakes fixed and ride it!
- Lead Member
Re: single carb ' Holley
Hi I too am running this same set up.." bought it used on e-bay" I'm not having ANY luck, it starts "only fully choked" idles great, stumbles when revved, "with choke on" after warm up, as soon as I attempt to open choke it dies.. I cant see any gas squirting from accelerator pump ? cleaned carb and put a rebuild kit. in "new accelerator pump" set floats , measured ,and set accel. pump rod, still same prob. any suggestions.?? OH my carb is mounted completely back wards from yours? could this be the prob. and I see you have the vacume line plugged? should I do this ? all so did you plug the original "vent" hoses that went to the orig. air box?? HELP !!! thanks man. UPDATE ..... weather was warmer this weekend, got the bike out, fired it up and rode it with choke" closed" when RPM's got to abot 3500 it started to "pop" and backfife a bit...opend choke and it took off like a rocket, ran great, when I came to a stop, it started to die...closed choke and it idled good ???
- Lead Member
what c f m is that carb ?
