saddle bag brackets
tiny2383
Zinc Member
Zinc Member
saddle bag brackets
Post by tiny2383 »
ok guys need your help yet again. curious if anyone has devised a way to attach leather saddle bags to a gl1100? i have some handmade bags that a good friend gave to me. i had them on my hd1200. so any help would be awesome.
http://www.ngwclub.com/forum/posting.php?mode=post&f=9#
http://www.ngwclub.com/forum/posting.ph ... 9&start=50#
"All men die, but not all men really live."
Anton G
'81 Gl1100 ~Matilda~
tiny2383
Zinc Member
Zinc Member
Re: saddle bag brackets
Post by tiny2383 »
nobody has any suggestions?
Anton G
Zacsdaddy
Post by Zacsdaddy »
A picture of the bags would help. I've made brackets to hard bags out of 1/16 steel plate and out of 1/2 inch tubing. Use the top shock for the front mount and the grab rail bolt for the rear mount. Depending on the weight of the bags and what you plan to carry you may need to devise a way to keep the back lower corners from rubbing on the tire.
Zacsdaddy
1981 GL1100 That Mama found and bought for me.
1975 KZ400D That I found for Her and brought back to life.
"If the Women don't find you handsome, they ought to at least find you handy" - Red Green
Yea I know Rebel had some on the first run and he lived out of them from Toronto all the way back to Reno. He had to rig something up to keep them out of the back wheel as I recall.
Zacsdaddy
Post by Zacsdaddy »
How were they mounted on the other bike?
Zacsdaddy
skydog
Post by skydog »
Here is Cookie's excellent solution done up on a 75.One piece of aluminum strap from the seat mounting bolt running down to the exhaust tip,held on by a u-clamp at the bottom.I added a cross brace halfway up and bolted the bag to this.Some cap nuts and it's all good! lolol
75 naked "Blue Streak" gone
78 fairing bags "Brownie" 4 sale
80 standard project 4 sale
84 Standard, Vetter bags "Horse with no name"
85 Interstate gone
84 aspy
86 aspy
"When the day comes to settle down,who's to blame if you're not around?You took the long way home"
alan hawke
My Album: http://www.ngwclub.com/gallery/v/wingmans//alanhawke
Post by alan hawke »
What i made up on my 75.
Alan
1975 GL1000
1976 GL1000
2000 ZX6R KAWASAKI
2009 vn1700 kawasaki classic
tiny2383
Zinc Member
Zinc Member
Post by tiny2383 »
that looks like something i could work with. on my sporty they just laid over the fender and tied to the shock
Anton G
FargoFour
Post by FargoFour »
I made some brackets for my soft bags on my GL1000. I'll take some picts tonight and post them here. I had two requirements,
1. The bags had to come off easy
2. The brackets had to come off easy
I think they look pretty go and seem to work.
I see you're in Albert Lea, I'm in Fargo.
Later,
Bud.
70 CL450
84 GL1200 A
98 GL1500 SE
Where there's a will, there's a relative. - Carlton Johns
FargoFour
Post by FargoFour »
I was trying to come up with a mounting system that had two ideas.
1. The bags needed to be easy to remove
2. The brackets need to be out of the way and easy to remove
Here's what I came up with.
Bags - An old set of Willy & Max leather saddle bags.
Stock - 1/8 x 1" flat
3/16 x 1 1/4" flat
1/8 x 1 1/4" flat
5/16 round
1. I cut the cross piece off the bags (the leather than went under the seat)
2. The vertical bar is made from 3/16 x 1 1/4" flat
3. The bottom horizontal bar is 1/8 x 1" flat
4. The upper u-shaped horizontal is 5/16 round
5. The bag L-brackets are made from 1/8" flat
I welded a flange nut into the turn signal mounting point for the vertical to bolt to and the bottom horizontal bolts to the passenger peg.
I then welded a bolt head to the bottom horizontal and cut a key-hole slot into the L-bracket. The key-hole slot goes over the bolt head. There's a loop on the bags near the top that loops over the upper u-bar.
There may be some changes coming but overall I like how they turned out. With the bags removed the brackets don't stick out at all. And like I said the bags are quick and easy to remove.
Bud.
70 CL450
84 GL1200 A
98 GL1500 SE
FargoFour
Post by FargoFour »
Here's some more picts.
The upper mont in the old turn signal mount point.
The bottom of the L-brackets. The key-hole slot is a little rough. I think I'd make the brackets out of aluminum next time.
With the bags removed, very sleek.
bud.
70 CL450
84 GL1200 A
98 GL1500 SE
tiny2383
Zinc Member
Zinc Member
Post by tiny2383 »
that might work too, only thing is im not handy with a welder. i did find a kit for older bikes, now its not for quick release but thats ok for me. http://www.speedmotoco.com/ProductDetai ... =SMCsaddle
Anton G
FargoFour
Post by FargoFour »
And by the time I add material and my time, the ones you point to probably cost less. But that's true of most things.
Good luck,
Bud.
70 CL450
84 GL1200 A
98 GL1500 SE
tiny2383
Zinc Member
Zinc Member
Post by tiny2383 »
this is what my bags look like with the kit from http://www.speedmotoco.com/ProductDetai ... =SMCsaddle , i love the way they look on there.
Anton G
Return to “NGW Club House”
