replacing stator with $40 GM alternator
- jake2012
I know how we like pics so here are some of a GM alternator installed under faux tank. Most know how expensive stators and related electronics are so this is a cheap alternative and excellent working replacement. This is a pic of it mounted
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1977 custom hawg chopper
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Re: replacing stator with $40 GM alternator
Another view. The stack is 2 stacks cut off original air cleaners and welded together. Unlike the poor boy kit she puts out 14.62 volts at idle with the 5" bottom pulley. and it looks better.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
I had to modify the tool tray so it would reach and seal on the stack
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Air cleaner installed
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Bought a $12 pulley from tractor supply and pinned it to the timing belt pulley. The belt was $6 from Napa. I had to grind the fins down on timing covers and left out the gaskets so as to not have to kick the radiator out to much.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
I just finnished grafting in some louvers for better air flow to filter.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
The rad is kicked out about 1 1/4" and still room to remove belt.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Bought a $15 10" fan from Amazon and it fit and works perfect.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- Zacsdaddy
Dang good lookin' modification.
Zacsdaddy
Zacsdaddy
1981 GL1100 That Mama found and bought for me.
1975 KZ400D That I found for Her and brought back to life.
"If the Women don't find you handsome, they ought to at least find you handy" - Red Green
- Dangeruss
Very nice, looks like a shoe horn fit, but the results are excellent.
Russ
2016 K1600GT
75 GL1000 Project
States visited by Goldwing...
2016 K1600GT
75 GL1000 Project
- Boufie
- My Album: http://tinyurl.com/2dma28f
WOW, that is one SLICK modification...
John B.
1978 GL1000
1978 GL1000
My hat is off to you!
How'd you pin the pulley? Any photos of that? Nice clean mod.
aussiewingman
looks excellent work...
i do have a simpletons question....
what do you do with the other alternator that the bike has?
Usually nothing. It doesn't hurt anything to just leave it in there.aussiewingman wrote:looks excellent work...
