replacing stator with $40 GM alternator
- brokentoe
Re: replacing stator with $40 GM alternator
Jake, you are one clever dude.
Faith, Family and Friends
'75 GL1000 (Feb 2012 BOTM)
2014 Softail Deluxe
First Fire on Youtube!
2014 Softail Deluxe
That's an excellent mod, Jake. And a very nice job on the instructions. Kudos.
- jake2012
Heyericheath wrote:How'd you pin the pulley? Any photos of that? Nice clean mod.
PS the best way to find the spot to drill is to first mount the pulley with some tacky paint on the face of the flange; this will leave the impression of the open area of the crank pulley. You'll then have the spot to drill the hole just inside the impression mark. The pin is about 3/16" if you mess up you can just try another hole on the pulley; but not to many. Oh and make the pin long enough to touch the face of the carank shaft and flush with the outer face of pulley.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1977 custom hawg chopper
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Thanks brokentoe. The truth is I live on a small fixed income and could never afford a stator so as they say necessity is the mother of invention. It also does'nt hurt to have been a wrench all my life. Thanks againbrokentoe wrote:Jake, you are one clever dude.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Hey OZman I just cut the yellows wire off at the block and sealed them with RTV. One day God forbid I have to open her up I'll just remove the stator for good and plug the hole where the leads come out of the case.aussiewingman wrote:looks excellent work...
i do have a simpletons question....
what do you do with the other alternator that the bike has?
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Hey dangeruss, Thanks! It is tight but there is plenty of adjustability and once you tie back the plug wires ,making sure all hoses and wires are secured and out of the way it's fine. I'll try and get some better pics of the adjuster side of the alternator bracket.Dangeruss wrote:Very nice, looks like a shoe horn fit, but the results are excellent.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Thanks! BoufieBoufie wrote:WOW, that is one SLICK modification...
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
- jake2012
Thanks Roady! Just tryin to help the brothers out.Roady wrote:That's an excellent mod, Jake. And a very nice job on the instructions. Kudos.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
Really Cool Jake, did mine on an 1100 somewhat like the PO Boy Conversion. My bikes a dresser so everything is hidden. That's a very good job hiding it there!!
Bob
Robert White
- jake2012
Hey Badorderbob! Dressers hide alot of stuffbadorderbob wrote:Really Cool Jake, did mine on an 1100 somewhat like the PO Boy Conversion. My bikes a dresser so everything is hidden. That's a very good job hiding it there!!![]()
Bob
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
Mounting it high like that really helps preserve the appearance of the bike. Looks very nice. Did you consider what drive ratio to spin that alternator at, a GL revs a lot higher than a car but your pulley is also smaller to compensate. So as long as you do okay at idle, I think you will be fine when you spin her up. And you kept the budget intact. Good work.
- jake2012
I did it trial and error in that the size pulley that made it charge good at Idle was the one I went with. As far as spinning at higher rpms I figure a Nascar spins them at 10 ,000 +; I should be ok. I did contact a guy that works at Delco and he talked with an engineer and he said the only posible issue was the brushes were designed for a rotation oposite a GW; however he said it would only slightly reduce the life of the brushes. I had a concern about the reverse fan and he said it will just pull air through instead of the more efficient push of the design. One can replace the fan with a $20 replacement that will push the air through the alt. He also mention that these alts. when hot automatically reduce output until they cool down. I guess time will tell worse case I have to buy another alt and pulley and still big bucks ahead of a stator and/or rectifier replacement.
and good ridin.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
My bet is your setup is fine. A pusher fan like yours blocks more airflow cause it contacts cooler air than the stock puller and that means the fan will come on a bit sooner at a given heat load. Guys with blowers make it work and you will also.
- jake2012
My bad Fred, I was refering to the fan on the alt being backward rotating. That $15 Amazon radiator fan is great.
Jake's past rides
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
1973 Suzuki TC 100
1976 Suzuki GT 550
1983 Honda ATC250R
1975 Elsinore 250
1952 Pan Shovel
2x 76 gl1000s
Hay Jake, my alt. is a 1-wire Ultra mini Denso 50 amp, but I did a little try-n-error to get a 2 to 1 ratio. Crank pulley is Don Pigotts' 3.5 he sells with his kit, I was just able to buy the pulley. On the Alt. pulley I came up with a Nascar pulley size 1.75 which gives me a 2 to 1 ratio. I also have a carb conversion which idles at 1150 but I up it to 1200 rpm which gives me 13.8-9. It will also charge higher when it calls for it at 14.2-3 but when everything is working as it should I get a 13.8-9 and that is with everything on,..........Sorry for long storyjake2012 wrote:Hey Badorderbob! Dressers hide alot of stuffbadorderbob wrote:Really Cool Jake, did mine on an 1100 somewhat like the PO Boy Conversion. My bikes a dresser so everything is hidden. That's a very good job hiding it there!!![]()
Bob
but this is the best way to do a nekked. Does yours work poorly like the Poboy or did you use a bigger pulley? a friend mounted the PoBoy kit and his only charged after 1500 rpm.
Robert White
