Will this valve spring compressor work?
Hamminahammina
Post by Hamminahammina »
I will be doing valve stem seals. Anyone see any reason el cheapo spring compressor wouldn't fit a 77 GL?
http://www.harborfreight.com/universal- ... 92900.html
They are finally opening a Harbor Freight in my neighborhood....can't wait
Thanks!
1977 GL1000
Re: Will this valve spring compressor work?
i have one like that, and use it when i don't want to remove the head. a little tricky, but it works. mine isn't from Harbor freight, so i can't talk to that particular one. but the style will work
Hamminahammina
Awesome, thanks! I was going by the how-to in shop talk and it just appears to be a different style than the one pictured there. I will pick this one up
1977 GL1000
bladredhead
Post by bladredhead »
i have a hazy recollection of someone using that one successfully, sorta. by buying 2 of them and swaping the arms around so they were the same length it worked fine. length didn't matter, just that they were the same length on each tool.
wayneperry
Post by wayneperry »
wow, what a co inky dink. Just bought one and i cant seem to get it to work right. these springs are so short and stiff, it wants to pop off. tried a few different ways and no luck yet. if you get it to work i'd like to hear about it and how to best go about it, thanks
1978 GL1000
Hamminahammina
wayneperry wrote:wow, what a co inky dink. Just bought one and i cant seem to get it to work right. these springs are so short and stiff, it wants to pop off. tried a few different ways and no luck yet. if you get it to work i'd like to hear about it and how to best go about it, thanks
Do you think it would work if both arms were the same length as blad suggested?
1977 GL1000
wayneperry
actually, just came from garage and got it to work. with the long and short arm, just reach it down as as close to the bottom coil as possible and start to snug down on turnstile, then i used another clamp to reach accross the arms and pinch them together alittle so they wont slip off when tightining down the turnstile. tighten it down, used a knife to wiggle loose the keeper collar and with pen type magnet, removed the collars and wall-ahhhh
1978 GL1000
Hamminahammina
Wayne, sweet success! good to hear
1977 GL1000
like i said...a little tricky
Qui-gon
Post by Qui-gon »
I did Caliif Wingnut's 1200 SEI valve seals by getting 2 HF spring compressors as mentioned above. If you swap the legs around so they are the same length it makes the job a lot easier. You can always sell the second one on. If you can find my original post on it there are some details about piston clearances at TDC etc.
1975 GL1000 Sold!
1976 GL1000 "GL1's evil twin" Supercharged cafe racer. Build thread Here
1977 GL1000 Black sorta resto project!
Now in Florida working for a living Ugh!.....projects on hold mostly!
Image Image
roachb
Post by roachb »
That's what I used. I am sure you could pay more and get a better one. For me this was probably a one-time tool so I went with HF. It was a little tricky but it worked.
Some auto parts stores will loan you one for free.
RoachB
'75 GL 1000
'79 CM400T
"If you're going to repair a motorcycle, an adequate supply of gumption is the first and most important tool."
- Robert M. Pirsig
Qui-gon
Post by Qui-gon »
1975 GL1000 Sold!
Image Image
Hamminahammina
Thanks Qui-Gon. I may try to borrow one with even length arms....or try this one form Sears, looks like more even arm lengths.
Other than smoke on start-up the engine's been running great.
1977 GL1000
Hamminahammina
Well the good news is I was able to rent one for free from O'Reilly's (used to be Kragen or whatever you call it in your neghborhood). The brand name was EverTough. Presumably because.... boy was it ever tough to get that thing to work right.
But the price was right!
1977 GL1000
ole496
Post by ole496 »
A large C-clamp with a hole ground in the end works like a charm:
1976 GL1000 "Double Nature" https://youtu.be/IK0YS2uuZtc
Our greatest weakness lies in giving up. The most certain way to succeed is always to try just one more time. -Thomas Edison
