Team #898 - Saved from the Ashes
Re: Team #898 - Saved from the Ashes
#181
Well Paul you best start collecting them as those of us in the rust belt can all use a nice one like that.
#182
More "Done" pics:
#183
Wow, Ernie, you have been very busy. Bet you are black and white all over.
#184
Didn't have much to do as the flu bug has not left the building. I decided to watch the basketball games in the basement while "working" on the bike. I figured that I have a lot of spare carb jets and was not sure what they were, so I figured them out one at a time. I used my handy dandy carb jet drill tool donated by Al (Dogboy) and it worked great. I did not have all the jet sizes, but could figure out what they were with the sizes supplied. As I am writing this I am thinking, OMG I need to get a life! Anyway, thanks to OhioBill we have a complete set of 75 jets. It should all work out once I get that idle tube figured out.
I then took some time to clean up the panels for the first time. They will look fine once I'm finished with them. A little touch up and some polish and we will be in business.
GL1-242
#185
Post by GL1-242 »
Look's great.
Do to a foot of snow the bracket will go out Monday.
Paul
84 GL1200 STD
75 GL1000 #202
75 GL1000 (AKA, GL1-242)(AKA, Flipper)
76 LTD
76/77 CB750F
Bultaco's = 121, 152, 167, 188
#186
Good work Ernie. That bracket is going to look great on the 898 Paul, way to go.
#187
She's gonna be a looker!
Beverages consumed .... (OJ, water, apple juice?)
GL1-242
#188
Post by GL1-242 »
The bracket and reflector is on its way.
Paul
84 GL1200 STD
75 GL1000 #202
76 LTD
76/77 CB750F
#189
Next team meeting scheduled for April 6.
Gord anim-cheers1
Oldewing
Secretary
Secretary
#190
Post by Oldewing »
Come one come all :crosso
#191
Finished up the panels. Two applications of rubbing compound, one of polishing compound and one of wax. Then some touch up on the striping and replace the pin.
#192
Nice work going on there Ern.
alwing17
Exceptional Member
Exceptional Member
#193
Post by alwing17 »
Hey,now!!! Ernie isn't the only one busy here! Brought the lump in the house finally and started to paint and detail the engine. I can only do a section at a time due to the fumes down here
Started putting the belts on and one of the tensioners was no good,So Greg was kind enough to send me a couple in the mail. I did notice when turning the motor over,a bit of rust in #1 cylinder...not bad,just a light coating.
I then painted the front cover and sourced the correct oil filter cover and bolt. Of course,the spring and shim was missing,so stop and dig through my spares for them
I will be replacing the front cover with new JIS phillips standard screws,as well as all the other JIS fasteners on the motor.
1975 GL 1000 "Street Fighter"
1976 GL 1000 Sulfur Yellow x2
1981 GL 1100 "Crown Royal"
1977 GL1000 Cirrius Blue
1977 GL 1000 Skidmark build
1976 GL 1000 Limited
2003 ST 1300 Silver Streak
alwing17
Exceptional Member
Exceptional Member
#194
Post by alwing17 »
Now that the belts are on and the motor timed,I oiled the cylinders and valve guides,hooked my jumper box to the starter,and proceeded to run a compression test,as well as pre oil the motor. The good news is the starter works good action1 Ran a bench top compression test to see where we stand...#1-75,#2-145,#3-155,#4-160. I ran more oil in #1 cyl,and the compression bumped up to 110. Sprayed some Kroil down the cyl and let it set o-nite,reoiled the cyl,and got her up to 150 today action1 action1 action1 . I think a few drive cycles when she is together,and we should be good. Today will be some more painting and detailing on the motor.
Coolant tubes and t-stat housing mocked up waiting for parts order to come in...maybe Tues. Hey Ernie...I found another emblem for the valve cover!!
Beverages Consumed,and Consuming Beverages!
#195
Way to go Al, those rings in cylinder 1 must be loosening up. Good to see the progress.
