any ideas?
longer fork legs for '83 interstate
- fish
I need to add about 1 or 2 inches to my forklegs 3 inches would be even better
any ideas?
any ideas?
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
- oldwings 78
Re: longer fork legs for '83 interstate
Still remodeling the Vincent?
terry
terry
"A man who is good at making excuses is rarely good at anything else" Benjamin Franklin
"A man who will sacrifice freedom for security deserves neither" Benjamin Franklin
'78s are the best looking GLs Just ask Doc
- fish
More like fine tuning
I am not looking for a chopper look.
Reemmber I am using a lower tripple clamp as a upper tripple clamp.
The stock upper has about 1.5 offset built inot it so when I put the "new" upper clamp on I hadda slide toe legs up 1.5, so the bike site about 1.5 lowre.
Also if I have longer fork legs I could have a little sticking up from my triple clamp and I could put my clipons up above the upper triple clamp/.
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
- 82aspy
seen a magna front end here that looked long on a wing,
used to be dude all he did was forktubes including custom longer on request, pretty sure still around but can't find info
ngw quotes
- \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
ngw quotes
Fish, you might be able to graft a newer 750 Magna front end on if they are 39mm. My guess is it'll be complicated to keep the 83 wheel and brakes. Mine required shimming to get the wheel centered because the Magna fork triples are narrower than the gl's. If you could find a pair that had been upgraded to the racetech suspension, you might get an upgrade to your handling.?? There was also someone here who made custom inserts to graft a pair of Busa forks on. Wingrider? maybe.
Forks by Frank. Get any length you want. longer or shorter. He can make you just the upper tubes and you can reuse your lowers.
+1 on forks by frank. i have used them in the past. good work
- fish
just called Franks.
They quoted 274 for 3 inches over
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
We did not say he was cheap, just real good.
How bad do you want the look....
Or swap something longer and redo the bearings and tree........300.00 bones will come rather quick me thinks.
IMHO here don't you know.
- 82aspy
http://www.ngwclub.com/forum/viewtopic. ... 35#p472335ericheath wrote:There was also someone here who made custom inserts to graft a pair of Busa forks on. Wingrider? maybe.
ngw quotes
ngw quotes
Dazzit!
- wingrider
82aspy wrote:http://www.ngwclub.com/forum/viewtopic. ... 35#p472335ericheath wrote:There was also someone here who made custom inserts to graft a pair of Busa forks on. Wingrider? maybe.
I can't take credit for those....bonneblktrk made those....he and I were putting Busa forks on at the same time....I did a little different route to make it shorter.
- hmratbam
They call 'em "slugs" A piece of steel same diameter as the fork tubes machined to screw in where the fork caps used to and as long as you want. I think those on the "Bopper" were 4".
My Album
84 Standard ongoing project
My Album
Good info Ron!
- fish
\hmratbam wrote:They call 'em "slugs"
YES YES YES
this is exactly what I want.
where do i get them
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
