Triple tree fork mods
82aspy
Post by 82aspy »
seen a bunch on this site and who knows where else all over the place
might as well have current info in one spot
the latest i stumbled on
Kawasaki GPZ 750 forks. This was for better brakes, and the anti-dive feature, and the 16” wheel.
http://www.metropulse.com/news/2009/may ... artner=RSS
Re: Triple tree fork mods
Also bolts straight up, as i recall
CYBORG wrote:Also bolts straight up, as i recall
Did you use the Kawasaki triple tree or are those forks the same diameter and spacing as a stock GL?
Now i remember. The GPZ forks are a bit larger then the wing. the stock triple tree was modified to except the GPZ forks
also the spacing of the tree is slightly wider, requiring a spacer on each side, on the axle, inside of the forks. Been a long time since i built Cyborg, and my memory isn't what it used to be....at least i don't think it is :lol:
82aspy
Post by 82aspy »
i'm aware of a few suzuki (1 gsxr at least) swaps done here 2 diff ways, a full magna swap with spacers, and a few more i'll be digging up
82aspy wrote:i'm aware of a few suzuki (1 gsxr at least) swaps done here 2 diff ways, a full magna swap with spacers, and a few more i'll be digging up
Sometimes it's just a matter of finding bearings with the correct dimensions for the neck and donor stem. Then changing the steering stops around to work with the lower triple you are using.
joedrum
Post by joedrum »
CYBORG wrote:also the spacing of the tree is slightly wider, requiring a spacer on each side, on the axle, inside of the forks. Been a long time since i built Cyborg, and my memory isn't what it used to be....at least i don't think it is :lol:
I know the problem lolol
1979 1000
82aspy
Post by 82aspy »
So I finally got around to installing the GSXR forks on my 1980 GL1100.
http://www.ngwclub.com/forum/viewtopic. ... 58#p543158
82aspy
Post by 82aspy »
http://www.ngwclub.com/forum/viewtopic. ... 04#p533104
I used the front end from an 03-04 gsxr 1000. You can find the bearings you need at http://www.allballsracing.com they have a nifty tool to search the bike you have and will list all the conversion kits for various front ends.
http://ngwclub.com/forum/viewtopic.php?p=478339#p478339
82aspy
Post by 82aspy »
http://www.ngwclub.com/forum/viewtopic. ... 90#p468790
The busa stem is not over long I think it will work by grinding some off the neck tube on the frame because the race on top is alot narrower than the orginal GL was,
http://www.ngwclub.com/forum/viewtopic. ... 42#p469342
73coupe
My Album: http://www.ngwclub.com/gallery/v/wingmans/73coupe/
Post by 73coupe »
I know someone who may be able make trees to fit GL1000 and have the correct spacing for the GSXR forks and wheels
I know he has made trees to fit Harley forks and wheels on a CB750 frame
82aspy
Post by 82aspy »
http://www.ngwclub.com/forum/viewtopic. ... ks#p526158
My original forks (on left with TRAC sticker in pic below) had caps on the bottoms so removing 4 nuts let the wheel & axle come out together. The new ones (on right in pic with the axle in front of the sliders) look much like the ones on your '77 (pic below my before & after), screwed into the left leg and with a pinch bolt on the right.
http://www.ngwclub.com/forum/viewtopic. ... 53#p530453
you might be able to graft a newer 750 Magna front end on if they are 39mm. My guess is it'll be complicated to keep the 83 wheel and brakes. Mine required shimming to get the wheel centered because the Magna fork triples are narrower than the gl's.
http://www.ngwclub.com/forum/viewtopic. ... 12#p494512
You can use 1100 or 1200 trees, they bolt on and then use 39mm or 41 mm forks from a donor bike. Dangeruss has a good write up on how to use cbr forks.
82aspy
Post by 82aspy »
82aspy
Post by 82aspy »
http://archives.wingworldmag.com/apr200 ... rings.html
The GL1100, GL1200 and GL1500 share identical steering stem bearings
http://www.allballsracing.com/index.php/forkconversion
http://www.allballsracing.com/media/pro ... 0Chart.pdf
checked out steering stem bearings for 84 gl1200, same bearings Part Number 22-1020 are used on
http://www.allballsracing.com/22-1020.html
Application Steering Brg - Seal Kit
Honda CB 1300 (Euro) 03-07, CB1000 94-95, CB1000C 83, CB1000R 12-13, CB1100 13, CB1100F Super Sport 83, CB400F 89-90, CB500F 13, CB500X 13, CB600F (599) 04-06, CB600F Hornet (EURO) 98-12, CB700SC Nighthawk S 84-86, CB750 C 80-82, CB750 Nighthawk 91-02, CB750F Super Sport 79-82, CB750K 750 Four 79-82, CB750L 79, CB750SC 82-83, CB900C 80-82, CB900F (919) 02-07, CB900F 81-82, CBF1000 (Euro) 06-12, CBF250 (Euro) 04-06, CBF500 (Euro) 04-06, CBF600 (EURO) 04-10, CBR1000F 87-96, CBR1000RR 04-07, CBR1100XX 97-06, CBR250R 11-13, CBR400 91-98, CBR500R 13, CBR600F 87-90, CBR600F2 91-94, CBR600F3 95-98, CBR600F4 99-06, CBR600RR 03-14, CBR900RR 93-99, CBR929RR 00-01, CBR954RR 02-03, CBX1100 79-82, CBX250 TWISTER (EU) 01-04, CBX750 (EURO) 94-01, CMX450C 86-87, CTX700 14, CX500TC Turbo 82, CX650T Turbo 83, GL1000 Gold Wing 77-79, GL1100 80-83, GL1100A 82-83, GL1100I 80-83, GL1200 Gold Wing 84-87, GL1200L/SEL Gold Wing 85-86, GL1500 88-90, GL1500A 91-98, GL1500C 97-00, GL1500CD 01-03, GL1500CF 99-01, GL1500CT 97-00, GL1500I 91-96, GL1500S 90-91, GL1500SE 90-00, NC700X 12-13, NSA700 DN-01 09, NT 650 (Euro) 98-05, NT 700 (Euro) 06-08, NT650 (Euro) 88-91, NT650 GT 88-91, NT700V 10-11, NTV 600 (Euro) 88-91, NTV 650 (Euro) 92-97, PC800 Pacific Coast 89-98, ST1100 91-02, ST1100A 92-02, ST1300 03-13, VF1000F 84, VF1000R 85-86, VF1100C 83-86, VF1100S 83-86, VF500C 84-85, VF500F 84-86, VF700C 84-87, VF700F 84-85, VF700S 84-85, VF750C 82-02, VF750C2 97-02, VF750CD 95-96, VF750F 83-84, VF750S 82-83, VFR 1200 10-13, VFR1200X (EURO) 12, VFR700 Interceptor 86-87, VFR750F 86-97, VFR800 Interceptor 98-09, VFR800XB (EURO) 11-12, VT1100C 85-07, VT1100C2 95-07, VT1100C3 98-02, VT1100T Shadow 98-01, VT500C 85-86, VT600C Shadow 88-07, VT600CD 93-07, VT600CD2 99-00, VT700 86-87, VT750C 98-14, VT750C2 07-14, VT750CA 04-14, VT750DC 01-06, VT750DCA 01-07, VT750RS 10-13, VT800 Shadow 88, VTR1000F 98-05, VTR250 Interceptor 89-90, VTX1300 03-09, VTX1300R 05-09, VTX1800 02-08, XL 1000 VARADERO (Euro) 99-11, Triumph America 02-13, Bonneville 800 01-06, Bonneville 865 T100 04-13, Scrambler 06-13, Speed Master 03-13, T100 02-03, T100 Bonneville 04-07, Thruxton 900 04-13
interesting for gl1000, shows 77-79 only
