The NGW Project Bike. Clutch renewal. Engine in frame.
Locked
octane
Post by octane »
With the blower instaled the clutch just couldn't cope
so decided to install a new one.
Here goes:
This is the set-up I refer to
NOTE: this is for the GL1000.
A few things that will come in real handy
when dong this job with the engine IN frame;
...a lift. Oh no , I wouldn't wonna do this lying on the floor;
everything is a bit tricky to get at, and it takes a while to do this stuff:
..a good selection of 10mm spanners, wrenches etc.
You don't strictly NEED all this stuff but I say;
the more the merrier ; there's a LOT of 10mm bolts
and some are hard to get at
..good light
preferably coming from below
Drain engine oil.
You still gonna need a container/rags under the clutch housing
as even when engine is drained, there's still oil in the clutch-housing.
It has it's own reservoir (and it's own scavenge pump).
Remove mufflers if you run the standard system.
The cross-pipe is gonna be in the way.
(Mine does not have the standard set-up, so I didn't remove it)
Remove the lifter cover (two screws)
..loosen clutch cable at the handle
and here where it goes into the clutch:
..disengage cable from the lifter:
...pull out cable from clutch housing
...remove the 8 bolts that holds the clutch cover
(shown here with engine out of frame)
It's an old habit;
I always make a cardboard thing for the bolts
so I know which will goes where, when assembling
...with the cover removed,
loosen the lifter-plate bolts.
IMPORTANT !!!!!!
Remove the bolts in small increments
alternating bolts in a criss-cross pattern
to avoid breaking the plate
(At least two of our honored members here
didn't do this, and as a result they broke the plate !!!)
..remove lifter plate and the springs
Open the lock tap securing the central nut.
Remember; it looks like this:
so don't forget to open ALL the little 'tabs'
Now, to remove the bolt a couple of
Honda special tools are called for, (more on that later)
but really all you have to do is
put a large screwdrive to the bolt
like this
..and give it a good firm wack !
That's it. At least it was for me.
..remove lock tab
..pull out the cluch center (holding back the clutch plates)
...and remove it by handling it OVER the frame cross-tube
..and down, between cross-tube and tire.
Inspect the clutch center for cracks and excessive wear.
..then remove the clutch plates
..remove pressure plate
Inspect in for cracks etc.
Here's what came out.
NOTE the order of the plates and where the damper-plate goes.
See diagram at the start of the thread.
NOTE that the first one that came out has larger 'tangs'
Check the free length of the springs
The service limit is 34.2mm, so these are fine.
As the clutch had trouble coping with the
power of the blown engine I opted for a set of stronger
springs:
These (on the left) are 10% stronger than standard.
Made by EBC (model CSK 10) and cost approx. 17$ for a set.
There are others made by Barnett and Lucas.
If, for some reason you want to keep your friction plates,
you must check for scoring and discoloration and
you're gonna check the thickness:
service limit is 3.2mm, so these are fine
(but it would be kind'a stupid not to renew them.)
For the same reason as above I went for a set of
performance clutch friction plates:
..these are, as you can see, from Barnett
Check the discs for warpage, by holding them down
with two fingers and inserting different feeler gauges
..service limit is 0.3mm
Check the release bearing
Check the function of the lifter-thingy
To see how to check it:
click the image below to watch a video of how the lifter works
when pulling the the clutch cable
(which will press the clutch plates apart, disengaging the clutch)
Check if lifter arm, moves freely
and check the oil-seal below the arm
..is it 'tight' around the shaft?
If not: replace.
Check the OUTER drum (still in there , in the engine)
...for nicks, cuts and indentations.
The bad news is that, if it's not OK,
you'll have to pull the engine out of the frame to re-new it.
Bummer !
Time to put things back together:
Pressure plate goes in
make sure it's seated right
Clutch plates goes in, in the RIGHT order
(see above)
after the friction plates have been in an oil-bath for like 10 minutes
..if you use standard friction-plates:
NOTE that the grooves must 'radiate' clockwise like this
Now for some reason (that I can't recall now)
I couldn't get in the whole package (plates AND clutch center)
so I had to first insert the plates AND THEN the center
after aligning the tangs
[EDIT:] at this point please check Randakks brilliant
tips on how to install the plates here: CLICK
Obviously, he found the solution that I couldn't figure out
and after a LOT of fiddling I got the center in
Make absolutely sure it's in ALL THE WAY
..it must be flush with the edge of the 'outer drum' edge
..insert thick 'washer'
remembering that the cupped face goes like this:
...then the lock-thingy and the bevel/central bolt
Using the special Honda clutch holder and the Honda
socket wrench (more on that later):
torque to 380 to 420 kg-cm / 28-30 ft-lb)
and lock the lock-thingy.
...springs goes in
..using a strong light and 'feeling' with a thin screwdriver
make SURE the springs are seated right
..on the plate-lifter
Install the 6 bolts
NOTE:
Tighten the bolts in small increments
..and torque to 100-140 kg-cm / 87-121 in-lbs
Install the clutch cover with a new gasket
and torque the 8 bolts to
Install cable and lifter cover.
Adjust the cable free-play.
New engine oil. Check the level,
and re-check after start-up.
THAT's IT
Useful info and links:
PARTS:
For clutch parts, friction plates/gasket/springs etc.
our friend Frenchy at his Moon Place:
Clutch parts
Don't know if he has the stronger springs but here's the parts #
...from Barnett:
Spring kit: 501-56-06015
Friction plate kit: 302-35-10002
and if needed
Tempered Steel Metal Plates kit: 401-35-078024
The oil-seal on the lifter-arm shaft comes from Honda:
('superseded) parts#:
91202-KFL-841 / Oil Seal 13.8 x 24 x 5mm)
'old' Honda parts#:
91202-216-003 / Oil seal 14 x 24 x 5mm
Price around 4$
TOOLS:
You can make that spacial Honda tool used for tightening
the central nut/bevel.
Here's a drawing provided by Member Whiskerfish:
and a photo of what he made:
Member Doncoyote11 used
"...a disk brake adjuster tool found at any auto parts store. This thing looks like a cube with various sized pins sticking out of it that goes onto a 3/8" drive extension. I had to try a few different sides to get one that fit close enough. You may have to hold pressure against it to keep it from slipping...."
and Member Domscorpiorlg informs that a suitable tool is
available from
(click) Motorcycle Toolchest
(Talk to 'Michael')
or you can get the Honda tool HC 41304. (if it's available?)
Or order from Amazon "Motion Pro 08-0015 Oil Filter and Clutch Hub Spanner 24mm ID" for $13 shipped Edit by Fred Camper March 3, 2023
Now for the 'holder' required to hold the clutch while
tightening the bolt/bevel, I really don't know.
(Honda tool# HC41303).
Maybe someone has an idea for that ?
I , myself was too much in a hurry for all this;
..put a big bolt in my vice,
..put a nut on it
..tightened/torqued it to 400 kg-cm
and whacked it back and forth using a screwdriver/hammer,
with the screwdriver whacked into a 'slit' in the nut.
(checking the torque a couple of times)
This gave me a 'feeling' of how much force was needed to
give the central bolt/bevel the right torque using the screw-driver method.
Then I applied that force when installing the bolt/bevel.
I'm NOT recommending this...just telling you
TIPS:
Be anal about cleaning the surfaces before installing
the clutch cover
..old habit from my time struggling with British bikes and cars,
I always do this when putting together surfaces behind which
oil in contained
Using a marker-pen I scribble on the surface
..then take it to a big thick piece of glass on which
I've taped some very fine (1000 and 1200) abrasive paper
..until all trace of the markings are gone
...meaning the surface is perfectly flat
and will hold the oil better.
Probably not necessary here but........hey, I won't hurt !
TECH:
IF your old clutch friction discs have disintegrated
the engine must be cleaned and flushed of debris.
(NO fun)
and here' what your screen probably looks like:
....and finally
CLUCH ADJUSTMENT
HAVE FUN !
Da' Supercharged Bulldog
Antoine de Saint-Exupery
Zryder
My Album: http://www.ngwclub.com/gallery/v/wingmans/zryder/
Post by Zryder »
WOW Octane I can't tell you how much I feel blessed we have you here . I personally and very humbly Thank You once again for all you do . tumb2 Keep On Keeping On .
Gary ... aka ... Zryder
1982 GL 1100 std. Custom Image
To my album ; http://www.ngwclub.com/gallery/v/wingmans/zryder/
very helpful.... and yes, it is SOOOOOOO easy to break the plate (having done it) and mother-honda has obsoleted the part, so the only fix is a bike breaker (got mine from frenchy!)
bandiso
Post by bandiso »
Hi Octane, B R I L L I A N T as ever.
Thanks for working for us.
http://goldwinggl1000.blogspot.com
My Album in NGW Gallery:
http://www.ngwclub.com/gallery3/index.p ... ns/bandido
TAPAS & RIOJA WINE FOR FREE WHEN VISITING BARCELONA ( NOT A JOKE )
mmstingray
Post by mmstingray »
Good grief, Octane. You're just amazing, man.
ICC
1977 GL1000 Wingray
http://www.nakedgoldwings.com/gallery/MMStingray-1977-GL1000
You ARE the man.
Great stuff.
THE LEGEND GROWS. :shock:
Gord :P
1CrazyMoFo
Post by 1CrazyMoFo »
Well, written, easy to understand......Octane have you thought about writing a book? Something along the lines of "How to keep your Volkswagen alive for the complete idiot".
Wow, a big screwdriver and a hammer, Octane (sniff) I Love You Man!!!
Peace,
Frank
The truth about Ape Hangers, yes they are very slimming.
muser3
Post by muser3 »
Thanks Octane! This will probably be my next project.
Sooooo well done!! :-D :-D
Lee
Muser3
The older I get the better I was.
East Texas
77 GL1000 Naked
78 GL1000 Vetter Fairing
80 R100RT
94 R1100RSL Black
94 R1100RSL Pearl Silver
Boxers All
82 Suzuki GS1100 gone to new OK home.
clockcycle
Post by clockcycle »
Nice, wow that's ALOT of patience required there..
Looks similar to the lockring/nut for a bicycle bottom bracket. I used to use the screwdriver hammer method.
Is that the same or similar tool needed to remove the fork triple tree nut?
Clockcycle
1979 Honda Goldwing GL 1000
Gallery http://www.nakedgoldwings.com/gallery/album171
Random notable guru quote; There are other possibilities, but they are "freakish" in nature.
octane
Post by octane »
Guys!..thanks for your kind words.
1CrazyMoFo wrote:.......Octane have you thought about writing a book? Something along the lines of "How to keep your Volkswagen alive for the complete idiot"...
Hi Frank, I've been asked that before
Like this
so it would be:
...mmmmmm now that would be fun!
octane
Post by octane »
clockcycle wrote:..
Nope.
For that you'd use this:
or a big scr..............naaa, never mind
1CrazyMoFo
Octane,
Well, looks like you have the cover of the book set up, so what's holding you back!!! I know I'd buy a copy.
Peace,
Frank
Absolutely outstanding work as always!!! Thank you Sir for you dedication to sharring your knowledge. I am sure that many old wings has been saved from the scrap yard from your postings.
Thanks Octane. Outstanding.
halbritt
Post by halbritt »
I plead guilty to having broken two of the clutch lifter plates. The first time, I believe that one of the springs weren't seated correctly. The second time, I used too large of a torque wrench.
Have you tested the clutch yet? What is the lever pull effort like with the stronger springs?
Locked
Return to “Octane's Corner”
