Wog's '78 Wild Child build
bladredhead
Re: Wog's '78 Wild Child build
#76
Post by bladredhead »
well i totally missed this thread. i blame... ummm... google?
anyway, i too was skeptical about the fins but they do look interesting in the end. nicely done. have you considered "no step" instead of a honda logo?
this would look even excellent-er with the material between the ribs removed, but only on the domed portion.... additional negative space or something. while it would ruin your mounting scheme for the plexi shields, i am confident you can overcome that minor setback anim-cheers1
wog
#77
Post by wog »
DocRoot wrote:I may be mistaken but I think those signs are made with the "vacuform" technology which heats the plastic and applies a vacuum to suck the soft material against a form. I am concerned that the engine heat would soften the plastic and that it would sag... and we don' want no stinkin' sag on no Goldwing riders (unless it is 'sagacious')
Good point,
I won't be using the same plastic that was used for the signs. Although, some came with the machine when I purchased it, along with the old block letters.
I'd use polycarbonate (Lexan) which has a softening temp around 300 degrees.
I'll need to get a GL1000 to operating temp and see how hot the belt covers get. I wouldn't think it would be over 200d or so.
#78
The cover temp is under 200F. Normally around 150-180
wog
#79
Post by wog »
CYBORG wrote:The cover temp is under 200F. Normally around 150-180
Thanks CYBORG anim-cheers1
bladredhead wrote: ...snip...
I thought about that also.
Easily done, but I think it would not leave much strength for the fins, but also would be a pain to clean up the inside cast "ribs"
They are easily seen when viewing from the top....
I might end up painting to complete the circle and sand down the fins.
Here's a sacrificed cover to show what I'm thinking...
I ordered some 1/16" polycarb today, so I guess I need to bring the vacuum form machine down, or get a longer 220vt cord and leave it up in the loft and get myself elevated. :IDTS:
El_Taco
#80
Post by El_Taco »
Will be waiting for the results, this project only gets better.
Terry in Australia
#81
Post by Terry in Australia »
Subscribed.
1986 GL1200i
#82
Post by HOTT »
yeah baby !! I likes :orange
wog
#83
Post by wog »
Trying to find time to get back to this "little" project.
Received the polycarb and should be able to play around with the vac form machine this weekend.
Did get a chance to clean up the road rash on the case guards and get them powder coated flat black.
Started with this
grind down the rust to get some clean metal to weld to
Tig on some filler
grind down to see what areas need more
coat, then temporarily mount
wog
#84
Post by wog »
I did think about cutting windows above the fins on the valve covers.
Maybe following the curves of the upper portion, but I agree, would just look like oil splashing around and you really couldn't see the "action" in there.
So, if I'm going to go this route...
I'll cut out more where the two red marks are so the contacts can be seen.
If it looks too much like Mickey Mouse, I might cut two more at the bottom. shakehands
OK guys, soooooooo, where else do I need a window to the inner working of the GL1000 before I start forming the windows? :roll:
bladredhead
#85
Gas tank. Definitely the gas tank
wog
#86
Post by wog »
bladredhead wrote:Gas tank. Definitely the gas tank
What gas tank?
I thought they were fake. lolol
Casper
#87
Post by Casper »
Nice job on rebuilding the engine guards. Your cutting holes in things to see, and show, how they function just reminded me of something I saw as a young boy. A bit more organic in nature, but I think the same idea. I grew up right across the road from the University of Alberta agricultural research facility in Edmonton. On Saturdays, you could go over there and they would let you walk around the barns, and some of the labs. It was 50 years back now, but I still remember this one massive cow, maybe a bull, I can't recall the genitalia. It had a glass window on one side of its abdomen, I had no idea what the heck I was looking at, but it sure looked cool. I almost went to Veterinarian School because of that.
Love what your doing with your build.
wog
#88
Post by wog »
Cool story. Maybe with this build I can get some youngens that see the bike to continue the tradition of keeping 'em on the road.
bladredhead
#89
What gas tank?
I assure you I am referring to the one under the seat and ibam as serious as a clown having a heart attack
RonHolly
#90
Post by RonHolly »
Some great ideas and innovations. Cant' wait to see the completed project! Nice work.
1977 GL1000
1998 Valyrie GL1500
