for those of you that have M.B.S. (multiple bike syndrome) and have the "silver wing" models.
as our sponsors also have supplies for those bikes and they are popular with the "wing" crowd.
The shop I got my 650 from replaced the shock with something like your picture. I don't believe they made any mods to the bike. I can check what shock they used if you would like me to
donlaubach wrote:The shop I got my 650 from replaced the shock with something like your picture. I don't believe they made any mods to the bike. I can check what shock they used if you would like me to
Don
Yes, please check.
AFAIK, the GL650 has a clevis mounting at the bottom of the shock unit, eye-type mounting at the top.
The original shock was designed to be rebuildable but I think the seals are NLA. A number of people on CX500forum.com have changed to shocks from other bikes and a few have even bought aftermarket replacements from places like Hagon (but watch what you get - I caught an eBay seller trying to sell twin coil overs that Hagon's catalogue said were correct for the pro-link only GL500).
BTW: The original shock does have a nice steel spring inside the housing where it won't get rusty.
Understood the OEM rear shock can be rebuilt, I'm just not a big fan of air shocks, riding/rebuilding them for years on MTBs, just prefer the ride quality of a metal spring shock with decent damping adjustments.
And my point was that the original does have a metal spring. You just can't see it because they put it inside where it won't get rusty.
If you really wanted to and you could source the seal you could put a preload ring inside the original shock, seal the air line port and run it with no air pressure.
But that would be a lot of work and the result probably wouldn't be as good as using the shock from something else. If you get the right one. Like I said before, go to cx500forum.com and ask there. A number of people have already done what you want and some have actually tried several shocks so they can tell you what not to waste money on.
