Pop's Bike
Terry in Australia
Re: Pop's Bike
#121
Post by Terry in Australia »
I just read this thread from start to finish, what a great build! My Department of Defence computer blocks Utube, so I'll have to wait until I get home to watch your vid. Cheers, Terry.
1986 GL1200i
Millwright
Re: Pop's Bike
#122
Post by Millwright »
Thanks Terry The video is not much, just wanted to show how easy it came up from the basement. The bike ran well all summer, it is a lot of fun to drive. Will start looking for another old wing to work on this winter.
Millwright
1983 GL1100 Standard
Image My build thread.
Terry in Australia
Re: Pop's Bike
#123
No worries mate, did the Webers need much setting up? I've got a spare 1200 engine which I'll eventually shoe-horn into a 1000 rolling chassis, and I'd like to install some webers, they look very cool. Cheers, Terry.
1986 GL1200i
Millwright
Re: Pop's Bike
#124
Terry The weber install went well. After running them for the past summer, I would do it again. They not only look good, they run well.
Millwright
Blackmagic
Re: Pop's Bike
#125
Post by Blackmagic »
Millright, where did you install the sensors for your air/fuel gauges? I'm looking to create this same setup on my GL1100. I already have the carbs installed and the bike runs but I just don't feel like I can really dial it in without the gauges. Thoughts?
Sagebrush
Re: Pop's Bike
#126
Post by Sagebrush »
This is a pretty old thread, Millwright is an occasional browser on this thread. You might get a quicker answer if you PM or email him.
Re: Pop's Bike
#127
Yeah .... he's a busy guy .... doesn't get here every day
Blackmagic
Re: Pop's Bike
#128
OK - i'll PM him
Millwright
Re: Pop's Bike
#129
Hello Blackmagic, the sensors for the air/ fuel gauges are installed in a short section of pipe I made to fit between the header and muffler on each side. Having the gauges
really made it easy to set up, and troubleshoot.
Millwright
Blackmagic
Re: Pop's Bike
#130
Were your sensors also Innovate products? One more question please - did you simply use the original headers and eliminate the mid cross over pipe when you added the supertrapps?
5speed
Re: Pop's Bike
#131
Post by 5speed »
what a sharp looking bike...you wingers and your darn lathes and milling machines. :( :mrgreen:
Re: Pop's Bike
#132
Well .... his handle is 'Millwright' ....
Millwright
Re: Pop's Bike
#133
Yes , the sensors came in the kit with the gauges, and I bought new replacement headers off Ebay. I used stainless tubing for the section to join them together that holds the bung for the sensors. Originally I had planned on installing the gauges only temporally, but they came in handy on more than one occasion. For example, a couple times dirt had entered into the idle circuit while I was riding the bike (before I took off the velocity stacks) and as soon as I pulled up to the next stop lights, I could immediately see that one side of the bike was running lean. I could tell the motor had a problem, but with the gauges I could see the problem was in the idle circuit. I just had to twist the throttle a little to go off the idle circuit and the gauges told me everything was fine. Without the gauges, who knows what I would have looked at as the problem. I then pulled out the idle screws on that side, blew them out and I was back running.
Millwright
Blackmagic
Re: Pop's Bike
#134
that is great information and exactly what I needed to know. Any chance you remember the model # of the gauges you picked?
