MotoNudo Build
Lads
Re: MotoNudo Build
Post by Lads »
This is a screen shot of the Honda parts I am looking at for the head job. On the right track? How do I find the exhaust gasket?
Lads
Re: MotoNudo Build
Post by Lads »
Robin, just saw your post. Will adjust this list based on your input.
Thanks
Re: MotoNudo Build
this looks like it will be fun to watch :popcornx2
Re: MotoNudo Build
Yep, it's getting interesting.
Lads
Re: MotoNudo Build
Post by Lads »
Occupied with the engine right now. In addition to the carbs, head job, and water pump I am considering the following:
Oil scavenge pump (not sure how big a job this is)
Clutch - 84 retrofit?? Saw the great post by Old Fogey
Electronic ignition?? I have seen some posts on the Dyna system.
I am not going to be using this as a race bike and want to include things that will increase reliability, ride-ability, and convenience.
On a different note, I will be scrapping the original tank and modifying the upper supports to accept a traditional tank. Looking at a 1979-82 CB750F tank, or possibly a Rickman style tank to balance the mass of the boxer-style engine. Either way I am looking for any guidance out there on this mod. Looks like sunnbobb has made a good habit of this.
Also will be lacing 16" rims on the front and back.
Here are some inspirations for the build. I know some of these bikes are much skinnier than the GW but I like the elements they incorporate.
Wheels/Tires
Tanks
Re: MotoNudo Build
I vote against the knobs.
rod willis
Re: MotoNudo Build
Post by rod willis »
good luck with this build and welcome to the form and as for the knoby's they might be
a good thing in Arkansas with they side roads the way they are lot's of dirt there also
you might take a look at Vesrah gasket I use them and have good luck with them there top end kit comes with just about everything that you need for the top end
Rod
rod willis
1976 GL1000
Re: MotoNudo Build
What Rod said. Enjoying this one.
Re: MotoNudo Build
Last summer, Westernhonda had head gaskets for $40 each. Exhaust gaskets, the copper rings, can be gotten from any local auto store they are the same as many cars. Check the cross references under Other References on the Shoptalk page.
Re: MotoNudo Build
OEM head gaskets for me. And the exhaust gaskets I got at NAPA were a touch small and did not hold themselves in the head like OEM. Also, about thd same price.
Lads
Re: MotoNudo Build
Post by Lads »
Thanks all. Getting a blend of OEM and aftermarket.
I appreciate the comments in rubber. Any suggestions for a good road tire that has a vintage look with an updated tread design?
Re: MotoNudo Build
tires are sort of like oil, folks have lots of opinions. I have a dunlop 404 on my Ltd, and one of the last elite II's on my 78. Dunlop stopped making a 17" rear in the Elite series.
Lads
Re: MotoNudo Build
#28
Post by Lads »
Working on the carbs today. Got the randakk kit and working my way through it. All the top jets seem to be correct and in the correct place.
Lads
Re: MotoNudo Build
#29
Post by Lads »
I was looking at the shocks on both bikes. MotoNudo has what I believe are originals. The silver bike has air shocks which I think were aftermarket.
Thinking about rebuilding the gas ones and putting them on the build and holding the others for the "original" bike. Any opinions on using the old shocks and the switch?
MotoNudo
Original Silver Bike
Major_moto
Re: MotoNudo Build
#30
Post by Major_moto »
Looking forward to seeing the heads/valves done-up. Getting ready to start tackling that job too......
