viewtopic.php?p=828681#p828672
Rear tire Rubbing very outside of the chicken strip
- Zinc Member
Ok guys 84 1200 Interstate I posted about air leaks but I don't think I have one anymore ( loose fittings) but I am still rubbing the very outside of the tire should i bend the ear of the fender the side near the gas tank or go with a smaller tire I really like the stock size being wide anyone had this issue. Thanks
84 1200 Bobber with American Flag Hydro Dipped
94 CB 1000
01 Shadow Spirit 750 DC ( Wifes )
05 Triumph Rocket III 2300 cc
2000 Honda Magna ( Wifes )
94 CB 1000
Re: Rear tire Rubbing very outside of the chicken strip
I wouldn't go smaller than the stock size, and if it is the stock size, then it shouldn't rub. Which means that something is not right (or left, lol). I would check the wheel and tire over carefully for alignment, wobble, or damage to the tire itself. My 2 cents!
Good wrenchin'
Todd
Good wrenchin'
Todd
Agree, I would inspect the installation very thoroughly. Get a print out of the parts breakdown and take it apart and make sure every single piece of the axle system is in place. Quite often a spacer or similar is missing or installed backwards.
There also is a specific order to tighten everything up when installing the wheel/tire. Don't have my manual handy, but IIRC, the axle needs to be tightened while the differential is loosely mounted; the diff is tightened last... I think!
as everyone else says, a stock sized tire should not rub, so something is wrong
- Zinc Member
I think i found the problem I have read several specs and all are different It has a 150/90-15 is the size supposed to be 130/90-15 some pages even go down to 110/90-15 so im unsure
94 CB 1000
94 CB 1000
Everything I've seen has a 150/90/15 on the back and a 130/90/16 on the front. I think your bike is saying, somtink wrong.
- gregforesi
It does sound like something isn't right. Maybe a spacer installed on the wrong side? The parts fiche should show the assembly order.
TrackT is correct in the tightening order if you've had the final drive off. Axle gets tightened first to align everything, and then the final drive gets tightened up to the swingarm. Once that is done, then it doesn't have to be done again unless the final drive comes off again. If the final drive gets tightened up first, it can cause a slight binding and quicker wear at the big drive spline.
If the tire is only hitting at one spot you could have a bent rim.
2006 GL1800 (Brutus Maximus)
another quirk about the 1200. If you take off the pumpkin, the drive shaft has a seal on it which inserts into the pumpkin (gear oil then lubes the splines of the shaft and the pumpkin)... anyway, if you take the saft off, you HAVE TO replace the seal or it will leak. To replace it you have to remove the shaft from the swing arm
- Zinc Member
It appears to have had shocks replaced the tire wear is even on both outside edges. ( still confused LOL )
94 CB 1000
94 CB 1000
- NCScooter
- My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
I can't add anything, but just for clarification, is it hitting the swingarm or the fender? Photo would help. If it is the swingarm, then the previous advice about spacers and such should be checked out.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
1976 CB400f
- 82aspy
1100 shock 13" - 1200/14.25" they both bolt up as do othersBearpaw wrote:It appears to have had shocks replaced the tire wear is even on both outside edges. ( still confused LOL )
ngw quotes - \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
- Zinc Member
Yes hitting the fender both sides and I forgot to mention they had to replumb air lines because the wouldn't work soiI will look at a 1100 shock and see if it looks the same . Thanks
94 CB 1000
94 CB 1000
- Zinc Member
Ok shocks measure 13 while on center stand so i guess 1100 shocks now shop for 1200 shocks any out there?
94 CB 1000
94 CB 1000
- 25 Replies
- 1120 Views
Last post by Not Done Yet
- 8 Replies
- 597 Views
Last post by Old Fogey
- 10 Replies
- 467 Views
Last post by KYpondman
- 4 Replies
- 603 Views
Last post by millerdog
- 4 Replies
- 725 Views
Last post by zoggystyle
