https://ngwclub.com/forum/viewtopic.php ... 81#p828672
Sending Unit Gasket, why your old one leaks:
elwood440
Post by elwood440 »
Somewhere on here I had read that a re-used sending unit gasket will "reliably leak," or something to that effect. I am working on mine presently, and took some new-vs-old pics of the gaskets. This is one of those parts that must be changed when you disturb the sending unit, and it is always recommended to replace it with a genuine Honda part.
Below I think you should be able to see for yourself WHY an old gasket will not seal.
83 GL650i parked for maintenance
79 GL1000 "Bad Idea" current ride
I do all my spannering myself
"There's no excuse for the things I'm about to do"
Earl43P
Re: Sending Unit Gasket, why your old one leaks:
Post by Earl43P »
I rejuvenated mine with brake fluid and it has not leaked.
I was careful to "seat" it back exactly as it came out.
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
mrtwowheel
Post by mrtwowheel »
40 years old and I've reused it over and over.
Scott
'86 1200 Interstate, alternator conversion, pinstriped by Charlie Buzzard
'75 GL1000, Blue Green, fermenting
Many more, mostly Hondas
Newbie, my ass
elwood440
Post by elwood440 »
Given the choice between trusting the one on the left, or paying $3.26 plus shipping for the one on the right, I'm going to go with the one on the right. That's just me though. YMMV
roachb
Post by roachb »
I certainly replaced my original gasket about 8 years ago. But I recently had it out and it looked fine so I put it back in. No problems. But I would not reuse the one on the left, for sure.
RoachB
'75 GL 1000
'79 CM400T
"If you're going to repair a motorcycle, an adequate supply of gumption is the first and most important tool."
- Robert M. Pirsig
