Loud screech/whine noise
rkortan
Zinc Member
Zinc Member
Post by rkortan »
When I started my bike yesterday all of a sudden it began to have a loud screech/ whine noise. I shut it down immediately. Today I got it onto the table and started it. The noise is coming from the stator area. It is still charging and runs fine except for the noise.
I don't know if I want to pull the motor and tackle this job but if I decide to what should I expect to find wrong with the stator. Any suggestions are greatly appreciated. Thx Bob.
IBA #48379
2010 Victory Vision
1978 GL 1000
1979 GL 1000
1979 Triumph bonneville 750 Special
1972 Norton Commando custom built by Ron Fraturelli
16 other bikes sold over the years
82aspy
Re: Loud screech/whine noise
Post by 82aspy »
at the back of the engine, unbolt a quarter+ sized cover that gives access to the rotor(?) securing bolt, that can backout
NCScooter
My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
Post by NCScooter »
Might it be the starter is not disengaging? Just a guess.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
Image 1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
olchris
Post by olchris »
IMO its the starter clutch not "engaging" correctly due to a weak or low battery... Give it a full charge and also use a jumper battery and try again ... You will most likely find the noise has disappeared!!....
1975 Goldwing #1 SOLD
rkortan
Zinc Member
Zinc Member
Post by rkortan »
I think I have it figured out. The screeching noise is being caused by the starter clutch. It sometimes just spins. Usually it works on the second try. It always starts and runs well. Cold blooded but runs smoothly after a few minutes. When I first got the bike the starter clutch took several tries to engage. When it's warm out first try works. Currently 33 degrees here. So probably the starter clutch rollers aren't fully retracting once the engine starts.
I don't really know what to do next. I was thinking of giving it a sea foam treatment to hopefully help loosen up the starter clutch rollers. If anybody has any good suggestions I would really appreciate them.
IBA #48379
2010 Victory Vision
1978 GL 1000
1979 GL 1000
whirrrrr.... thunk! mine loves to do it when I am at a gas station and lots of other bikers are around
rkortan
Zinc Member
Zinc Member
Post by rkortan »
Got it to work correctly. Sprayed PBBlaster onto rotor as I turned over the motor by hand. Started it brought it to operating temp. Sprayed the PBBlaster again. Let it set while I did chores.
Took it off table made a run and held motor a 5 grand a few times in 3rd gear. Came back to house and she idles with no extra noise.
I know I need to replace the started clutch rollers and springs but maybe this will work til I get motivated.
Looks like my other bikes will get some riding time
IBA #48379
2010 Victory Vision
1978 GL 1000
1979 GL 1000
dl1000
Post by dl1000 »
Good news is the parts aren't too expensive.
1978 GL1000.....KATE Daily ride
a very wise man once said nothing
gregforesi
Post by gregforesi »
A crankcase flush will often cure the "sticky roller" issue. I've come across references to the rollers developing flat spots and needing replacement, but I've never seen it.
2006 GL1800 (Brutus Maximus)
brokentoe
Post by brokentoe »
rcmatt007 wrote:whirrrrr.... thunk! mine loves to do it when I am at a gas station and lots of other bikers are around
Yes our bikes like to humble us once in awhile.
Faith, Family and Friends
'75 GL1000 (Feb 2012 BOTM)
2014 Softail Deluxe
First Fire on Youtube!
82aspy
Post by 82aspy »
almost dropped mine the other day just moving the lug crying1 around
rkortan
Zinc Member
Zinc Member
Post by rkortan »
Started the engine flush today. 50 miles again tomorrow then change oil and filter.
My fall project is clean carb slides, adj valves, sync carbs, clean bike and ride it like she's 37 yrs old.
IBA #48379
2010 Victory Vision
1978 GL 1000
1979 GL 1000
RB
Post by RB »
There is another "fix" drilling a hole in the right place, install a port so you can spray solvent directly at the rollers. There are a couple of threads with pics..on this site. 3rd pic shows the "cleaning" with the engine out and cover off..but where the hole gives you access to the cleaning ports on the clutch itself.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
rkortan
Zinc Member
Zinc Member
Post by rkortan »
Now that is a great idea. Put in a cleaning port to use when needed.
Add that to my project list. I will use my extra engine to measure and make sure I place it correctly.
IBA #48379
2010 Victory Vision
1978 GL 1000
1979 GL 1000
82aspy
Post by 82aspy »
http://www.ngwclub.com/forum/viewtopic.php?f=1&t=58522
http://www.ngwclub.com/forum/viewtopic. ... 15#p642915
For drillers, you'll probably get better advice at a machinists forum, but I experimented on a sacrificial piece of aluminum first. I found it best to keep lots of grease around the drill bit so that you could see it swirling and pulling shavings up and out. In my first attempt on the sacrificial piece, I stopped when the drillbit was going through. I did this above of a piece of paper towel so that I could see if anything would fall, and a big hunk of grease and shavings did fall in. The second time I maintained the drill moving all the way until it went through, it is difficult without it wanting to catch it at the end, but I slowed down and it went through cleanly. If I were to do it again, I think I would make "dam" of clay to keep a reservoir of grease around the bit. This was dangerous.
