I particularly like the little peak at the top of the rear hoop, nice touch
GL 1000 cafe fighter
- Norbert R
Re: GL 1000 cafe fighter
Your frame looks fantastic - good lines to it, the motor looks really nice in the there.
- EHE
thanks!
yes my health is okay enough to spend very long hours in the workshop
so I'm not complaining at all
- EHE
yesterday I spend hours searching for the right air filter that is big enough en fits in between the carbs and the gastank
this one should just fit in...f
I will have to make a top shielding myself cause the Original K&N one makes it much to heigh. But that will work out just fine.
but to make sure I made a paper dummy and i think it will really fit... or I will modify the bottom of the gastank to make it fit. Cause now I have about the same amount of aircleaner surface as before with this set of carbs on the sidecar.
this afternoon also picked up a nice set of disc brakes that suit the wheels better (and the one I used to make them fit I had only one piece of laying around)
- Norbert R
That air filter will look good, especially with an EHE cover
Do the bolt holes on the discs line up with the hub, or will you need to modify ?
- EHE
The bolts line up, the inner diameter of the disc is a little bit bigger then original GL and also the offset, but if you scroll back a few pages you can see i already made adapters for that.
Dimensional this is the same disc as the one with the round holes, just different layout
mhynze
I think some paint stripper would add a nice touch to the tank
1977 GL1000, with GL1100 engine and carbs....in progress
1984 GL1200 Ascenpade gone naked...............in progress
1976 GL1000 1200 Engine, 1200 wheels...........in progress
1983 GL1100 Stock, fully functional!
1982 GL1100 ..................................................in progress
1976 GL1000 Stock resto....................... .........in progress
1978 GL1000....Upgraded...Bad cylinder............in progress
1982 CB900, 83 GL1100 rear end, 2006 gsxr1000 front end, 1200 front wheel..... in progress
1981 CB750k Needs attention.... in progress
The more time I spend on here the farther behind I get
cool beans ehe
- EHE
how do you mean that about the paint stripping?
- EHE
I've been working on the electrical things.
first start to build the small battery I've been talking about for already a few years
couldn't find any proper bridge connections so I made my own from 5x1,5 mm cupper strips lots of soldering, but it seems to work
- EHE
then try to figure out the best position of the few electrical part I'm going to need to get this baby running.
want to put it all in the seat compartment and as far as I can predict, I think its going to become a very compact cable routing.
the regulator will be mounted on the outside of the seat compartment. nice big cooling surface and in the fresh open air.
Need to find a key switch which also has a start functinon in it (like in a car) and then mount this part also very close to the seat compartment.
Looks great EHE, looking forward to how it works out. This has been a long time coming.
- Norbert R
Nice setup EHE, that battery looks super compact
UK_Andy
http://www.ebay.co.uk/itm/Deans-Probars ... SwT6pV1E8C
we used to use these in rc racing to make battery packs
- EHE
thanks Andy, always handy to know where to find them afterwards
(I'll keep it in mind for the next time. could safe a lot of time, allthough the home made ones work perfect as well
in the meantime she got on her own feet and because of the whole supsension setup was a wild guess... I was happy to notice it feels very wel in balance with the engine in the frame been puzzling a lot with different headlights and different positions, but this is how I ended.
To me that headlight doesn't go with the rest of the style.
