viewtopic.php?p=828681#p828672
Neutral Light
- Zinc Member
Neutral Light
Finally got my 1983 GL1100 on the road yesterday....runs good and rides good.......one thing I noticed was everytime I pull the clutch lever the neutral light comes on! This doesn't seem like it should be because when I get ready to park and shift to neutral the light is on even though I am still in gear so I can't tell when I am actually in neutral.....any ideas?
- roncar
Re: Neutral Light
Shorted neutral diode.
http://www.ngwclub.com/forum/viewtopic. ... 21#p135721
The neutral diode is placed between the neutral switch and clutch switch (and the starter relay). As a diode will only pass electrical current in one direction, this allows either the neutral switch or the clutch switch to apply “ground” to the starter relay. However, when the clutch switch is activated, and the neutral switch is not, the current will not go through the diode and apply the ground to the neutral light. Therefore if your neutral light “lights” when you pull in the clutch, the diode is shorted and needs replaced.
- gregforesi
Re: Neutral Light
Is the 1100 the one with the neutral diode wrapped up along the wiring harness someplace? I know Honda kept moving it and I seem to recall that on a couple of models they were tough to find.
2006 GL1800 (Brutus Maximus)
Re: Neutral Light
yesgregforesi wrote:Is the 1100 the one with the neutral diode wrapped up along the wiring harness someplace? I know Honda kept moving it and I seem to recall that on a couple of models they were tough to find.
- Zinc Member
Re: Neutral Light
Thanks I will check that outroncar wrote:Shorted neutral diode.
http://www.ngwclub.com/forum/viewtopic. ... 21#p135721The neutral diode is placed between the neutral switch and clutch switch (and the starter relay). As a diode will only pass electrical current in one direction, this allows either the neutral switch or the clutch switch to apply “ground” to the starter relay. However, when the clutch switch is activated, and the neutral switch is not, the current will not go through the diode and apply the ground to the neutral light. Therefore if your neutral light “lights” when you pull in the clutch, the diode is shorted and needs replaced.
- 3 Replies
- 516 Views
Last post by Track T 2411
- 8 Replies
- 671 Views
Last post by redglbx
- 11 Replies
- 484 Views
Last post by sunnbobb
- 5 Replies
- 1069 Views
Last post by flyday58
- 5 Replies
- 652 Views
Last post by jdvorchak
